Question about Vacuums
I have a 4-5 year old days on that makes a horrendous vibrating noise when I turn the carpet beater brush on. I have cleaned any misc debris from that brush area but the noise is getting worse.
SOURCE: The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Posted on Mar 28, 2009
SOURCE: 2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
Posted on Jun 02, 2009
SOURCE: ratchet noise, beater will not turn, belt not
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Posted on Aug 23, 2009
fathitkf
  • 1871 Answers
SOURCE: The beater brush wont spin because the brush roll
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 22, 2010
Strattrpt
  • 159 Answers
SOURCE: The beater brush doesnt work
It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you should see several screws holding a faceplate in place. Unscrew these, and you should be able to get access to the beater brush and belt. Pull on the belt a little -- if it has a lot of give, or seems stretched or cracked, replace the belt and your vacuum should be fine. If it is not stretched or cracked, move the belt and look between the belt and where it holds onto the brush (there should be a little groove that the belt is sitting it). If there is a lot of debris or hair (I have long hair and this happens to me quite often) between the belt and the brush bar, clean it out, and you should be good. The squeaking noise leads me to believe that the belt is stretched and could be replaced.
Posted on May 26, 2011
The beater brush doesnt work on the carpet and makes a loud squeeking noise.It looks like the brush sticks out past the base and gets stuck on the carpet . Works good on the bare floor.
May 26, 2011 | Shark Navigator Bagless Upright Vacuum
My Hoover Wind Tunnel has no suction, unless I use the hose and wands. It is less than a year old. Where do I take it to get repaired?
Before you take it anywhere, please check the following:
1- Make sure the belt that runs the beater brush on the bottom has not broken. 2- Be sure the beater brush has not frozen up due to debris. You should be able to move it by hand. Best to remove the brush, clean all debris as best you can and add some WD40 to the rubber pieces at each end of the brush. Turn the rubber pieces to work the WD40 into axle at the end of the brush until they move easy and reassemble.
If you find this information to be of help, please go to the rating section of FixYa and provide me a rating.
Paul
Sep 23, 2010 | Hoover U6630-900 WindTunnel Bagless...
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Brush doesn't turn when on carpet
This sounds like the beater brush drive belt is either slipping, off the pulley, or broken. Unplug the vac, turn the unit over, and remove the bottom plate which may require you take out some screws.
Depending on your model, you will see a belt on one side or the other of the pulley and beater brush assembly. It's usually best to replace the belt, especially if the vac is over a year old. This is also a good time to clean any debris from the brush and the immediate area.
If you aren't comfortable doing this sort of work, just about any vacuum cleaner or appliance repair shop can handle this if you have one in your vicinity. Shop around.
Dec 25, 2009 | Bissell 3920 Bagless Upright Vacuum
Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Animal Vacuum - terrible loud noise
I have purchased six Dyson DC14 vacuums on eBay at rediculously low prices as they were being sold "as is" because they made a "terrible noise" when the brush bar was engaged. Each of the vacuums I received were like new, literally, and did make the terrible noise that was described. For less than $25 each, I purchased replacement beater bars (brushrolls) from an eBay seller in England and ALL six of the vacuums work perfectly.
When I dismanteld each of the units, some beater bars only had hairline cracks and and others were falling apart. I first purchased beater bars from eBay that were very cheaply made and broke within one or two weeks. The beater bars I got from England have been going strong in a commercial business for over a year now. That's equivalent to 5 years use in a residence.
Defective beater bars are more frequent than most people realize. I'd lay odds that is your problem but you will never know until the beater bar is removed and closely inspected. Some fractures of the plastic can be hard to see.
Hope this helps.
Mar 01, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Jun 08, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush roll slows/stops turning
when you removed the beater brush did you clean all the lint and threads off the ends of the brush? you can unscrew one end of the beater brush plate to clean the crap off it. Inside the beater brush are two ball bearings. Use a light machine oil to lube these two bearings. re-assemble the rod and end nut. then put your brush back in the machine and note which direction the belt needs to be installed. there'll be an arrow on the motor housing.
Sep 05, 2007 | Kirby G4 Bagged Upright Vacuum
What I found was that it is the roller brush. If you are willing to get a little dirty and do it yourself, there is the roller brush that most likely needs to be cleaned. After a little tinkering of my own, the roller brush can be slipped out or just shift it out of place to clean it. There are two ends to the roller brush and the brush itself. Of you twist the two ends until the come apart you would probably find a lot of hair and other long strand items wrapped around the rod that goes through the brush. Once you clean that out it should work like new. If that does not work then it is probably the clutch which is what the belt around the roller brush is connected to. Hope this helps, it is a simple solution.
Jul 30, 2007 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
