Question about The Computers & Internet
I need to know the equivalent of JCS5N50FT please.
What is equivalent to 6/8?
There are an infinite number of fractions equivalent to 6/8. Reduced to lowest terms, it's 3/4. Some others include 9/12, 12/16, 30/40, 60/80, 75/100, 300/400, 600/800, and 6000/8000. As a percentage, it's equal to 75%.
Feb 04, 2014 | Office Equipment & Supplies
What's a number equivalent to 100 using only the number nine
99.9999 repeating is technically equivalent to 100, depending on what level math you're in.
For example, 100 / 3 = 33.3333...
but clearly 33.333 * 3 = 99.9999...
So multiplying both sides of my first equation by 3, we get 100 = 99.9999
If you are not looking for "a number equivalent to 100" but "an equation or set of numbers equivalent to 100", then there are many ways. For example:
99 + 9/9 = 99 + 1
And 99 + 1 = 100
Jan 16, 2014 | RXE160 Equivalent NTE16013-ECG POLYMERIC...
What is the network equivalant key and where can I find it?
The network equivalent key is a terminology used by Apple and its router type called Airport Extreme to identify the WiFi security password in a different way.
The D-Link DI-604 is a router without wireless (WiFi) capability and therefore there is not security key at all.
Please let me know if you need more details
Best regards
Mar 12, 2011 | D-Link Express EtherNetwork® DI-604 Router
Oil pressure gauge not working ,need to know location of same.
Oil Pressure Sensor Testing
  1. Check the oil level and correct as necessary. Turn the ignition switch on, but do not start the engine.
  2. Disconnect the sensor lead at the sensor. The gauge should read full scale.
  3. Ground the connector. The gauge should read at the bottom of the scale.
  4. If the gauge functions properly, replace the sensor.
4.8L, 5.3L & 6.0L Engines
  1. If necessary, remove the engine sight shield.
  2. Disconnect the oil pressure sensor electrical connector.
  3. Using J 41712 or equivalent, remove the oil pressure sensor.
To install:
  1. Apply sealant to the threads of the oil pressure sensor.
  2. Using J 41712 or equivalent, install the oil pressure sensor.
    • Tighten the oil pressure sensor to 26 ft. lbs. (35 Nm).
  3. Connect the oil pressure sensor electrical connector.
  4. If necessary, install the engine sight shield.
Dec 07, 2009 | 2004 Chevrolet Avalanche
I need a new needle for my Garrard 40B turntable
contact this company and ask them if they have the correct replacement or a suitable equivalent?
mailto:info@needledoctor.com
Jun 04, 2009 | Audio Players & Recorders
Remove/replace shock absorber assembly 900s 1995 saab
  1. Slightly loosen hub center nut when all four wheels are on ground.
  2. Raise and support vehicle, then remove five wheel bolts and wheel.
  3. Remove hub center nut, then the wheel sensor,
  4. Press back brake piston using slip-joint pliers,
  5. Remove caliper from steering swivel member, then suspend in wheel housing with cable tie.
  6. Remove brake disc and back plate, then slightly loosen tie rod end nut.
  7. Press out tie rod end nut using puller tool or equivalent.
  8. Remove nut and tie rod end bolt, then the anti-roll bar to swinging arm nut.
  9. Remove outer ball joint nut.
  10. Press ball joint out of steering swivel member using puller tool or equivalent, installed on spring link.
  11. Remove nut and discard. This self-locking nut must not be reused.
  12. Remove three upper mounting nuts for MacPherson strut, then the strut.
  13. Clamp MacPherson strut in vice.
  14. Compress spring using spring compressor or equivalents.
  15. Hold piston rod and remove nut using MacPherson strut socket tool 89 96 662, or equivalent. This is a self-locking nut and must not be reused.
  16. Remove mounting and top spring seat, then the coil spring, gaiter and compression stop.
  17. Unscrew damper using wrench tool No. 89 96 670, or equivalent, then remove damper from strut.
  18. Reverse procedure to install, noting the following:
    1. Screw damper in place using wrench tool No. 89 96 670, or equivalent.
    2. Lower end of coil spring should abut against stop in bottom of spring cup.
    3. Position MacPherson strut on vehicle and install three retaining nuts on top mounting. Tighten nuts alternately, according to specifications.
    4. Always use new hub center nut with self-locking threads.
Jun 04, 2009 | 1995 Saab 900
Need to know the polarity of the dc3.5v input on sx100is please.
Hi - Check the following web site for an equivalent charger:
http://www.batterygenie.com/ac-adapters-5/digital-camera-camcorder-39/canon-adapters-41/ack-800-ca-ps800-equivalent-ac-adapter-147.html
If you enlarge the picture you can just make out it's center positive:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 08, 2008 | Canon Cameras
Need equivalent IC
i made programmer for 89c51. in this use ic ds275. i want know what is the equivalent ic of ds275.
Aug 10, 2008 | LG F-185 CD Shelf System
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Darren  Means
Darren Means
d3yavu3
kimblebear
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
