Question about Delta Plumbing
Trying to fix my single lever Delta faucet. It is a single lever .I bought the repair kit that does both old and new styles. Now it squirts out the top Could I have.. put the springs in backwards?
dragonsthatk
  • 547 Answers
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Posted on Feb 26, 2009
  • 244 Answers
SOURCE: My Delta single handle shower faucet drips constantly
call delta and describe the round plate and the screw locatios. they can identify model. you need a new cartridge they costs $25-60. They may send to you for free.
Posted on May 09, 2009
meBNme
  • 334 Answers
SOURCE: repairing a delta single shower faucet. The handle
There is a nut that needs to be removed, allowing you to remove the ball assembly.
Look at the ring nut right below the #1 in this pic.
Your's should be similar to this one.
Posted on Oct 03, 2009
  • 5 Answers
SOURCE: Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Posted on Dec 27, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
The faucet drips constantly from a single handle tub. How do I fix this?
we would need a little more information but sounds like it will need replacement, The water will eat up the meatle and make a rebuild impossible sorry but no quick fix the hot water lineis usley the culprit
Aug 09, 2017 | Plumbing
My delta faucet 172-sswf waterfall single handle kitchen faucet is leaking at the handle or lever how do I repair it?
i forget what the piece is called exactly but if you go to home depot or lowes or where ever and give them the type style and brand of your faucet and tell them what it's doing they will set you up with the new part. it's sort of a core type piece with rubber o-rings on it
Jul 13, 2012 | Delta Faucet Delta 172-SSWF Waterfall...
Stuck facuet cap (Delta single lever 174WF)
tapping it side to side helps.
Oct 07, 2017 | Delta Plumbing
The sigle lever on my kitchen tap has become almost impossible to lift up and down or sideways please any suggestions,we have removed the round cap from the top and poured descaler down it but no response
you know my grandfather was a carpenter and for some reason he loved Delta faucets. My dad hates delta because they always leaked. We have gone around to all the rentals and even this house he built and replaced all the delta faucets with nice quality moen faucets. You will need to get a washer kit for this faucet. These kits are pretty common since these faucets are so junky. Most hardware stores should have the repair kits. like home depot and Lowes.
Jul 20, 2010 | Delta 2402 Classic Single Handle Kitchen...
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
I have delta palo model kitchen faucet that has a
Delta faucets have a lifetime warranty. Call them and tell them, they will send you a rebuild kit. You can rebuild the whole faucet, it will work like new again.
May 02, 2010 | Delta 467-SD Palo Single Handle Kitchen...
How to fix leak for delta faucet 470 WHRS
To fix the leak in delta faucet is have a repair kit for
Delta 470-WHRS. The repair kit consist of O-rings
replacement. Otherwise, you have to buy a replacement
for your Delta 470-WHRS.
Nov 26, 2009 | Delta 470-WHRS Signature Single Handle...
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
Need Delta kitchen faucet repair kit # for model # 172-WHWF
you can generally purchase this kit at any plumbing supply store, or a home depot, or on line http://www.repairclinic.com/
Aug 19, 2009 | Delta Faucet Delta 172-WHWF Waterfall...
WHEN FAAUCET COMPETE SHUT DOWN AND STILL LEAKING
Delta Single lever? Remove handle by loosing the allen screw . Tighten the spanner clockwise. If that doesn not fix problem, turn water off, remove spanner nut. Remove whole assembly. Take to plubming supply and latch us for rebuild kit.(two rubbers, two springs,. a spanner wrenchand an allen wrirenc and maybe a new spaner nut) Install same.
Mar 10, 2009 | Plumbing
Plumbing Logo
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
