Question about Irons
Is there a anti-calc tablet or something for de-scaling the HIN 172 ?
White flakes coming from iron when doing a laundry.
    Top Expert:
  • Irons Master
  • 24,445 Answers
Run a tablespoonful of white vinegar through the iron to remove calcium deposits and then use de ionised water from then on to avoid it happening again.
Posted on May 19, 2017
Testimonial: "Thank you, much appreciated."
  • JonSnell Electronic
    JonSnell Electronic May 19, 2017
    The acetic acid in the vinegar 'eats' the chalk.
My steam iron has calcified outlets although have regularly emptied the machine through the outlet, therefore not working properly
its a great iron no argument there
de scaling products can only do so much
even if using demin water or filtered water
they dont last forever
Nov 09, 2016 | Tefal Irons
Is my steam iron broke?
Get a new one. If it drew enough power to trip off your electricity then there is a problem that is not worth taking a chance on.
May 07, 2017 | Irons
We have a GC8420 steam iron. The steam is regularly discoloured, first a pink, chalky stain - very difficult to get out of fabrics - and today a lot of dark brown/black water coming out. We do empty out...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Jul 14, 2011 | Philips Irons
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
How do I anti calc my simac stirella steam iron
I would suggest trying white vinegar first and then something stronger like lime away or CLR if it does not unclog for you. Same procedure used for coffee makers.
Eric
Aug 16, 2010 | Irons
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Aug 04, 2009 | Sunbeam Irons
I've lost my cleaning instructions
Remove the anti-scale valve from your iron and leave it overnight in a cup of white or distilled malt vinegar or lemon juice.
The soleplate can be cleaned using warm water and washing-up liquid on a plastic scouring pad suitable for non-stick coatings. For stubborn stains, use Hi Speed found in your local supermarket in the laundry isle.
Jul 03, 2009 | Tefal Irons
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 | Irons
Irons Logo
141 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
