Question about JVC KD-S680 CD Player
Wire harness diagram
Where could i find a wire diagram for the wires for the plug that goes in the back of the stereo my boyfriend is trying to change the stereo and had to get a new plug for it and dont know how to put the wires back together
  • Anonymous Mar 20, 2014
    need complete wiring diagram
    for dxt-2266ub
  • Anonymous Mar 24, 2014
    hoocked up stereo according to wiring diagram and stereo keeps going into protect mode. Made all connections with **** connectors so they wouldn't be any loose connections.Didnt change speakers yet probably worn out if that may be the problem would like to know.
  • 132 Answers will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Posted on Jan 02, 2008
Need a wiring diagram for a 1997 Hyundai h100 stereo.
Your best bet is to get an harness adapter that will let you wire the stereo then plug it directly into your factory harness. Check out
Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Good luck
May 21, 2016 | Hyundai Cars & Trucks
Pontiac grand am wiring diagram
You will need the wire harness that is designed to connect to the stock stereo. Another option is to just install your alpine stereo in the car since you have the wiring harness for that. You will not be able to wire the harness for the alpine unit and have it match the plug type for your stock stereo.
Dec 12, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
I have no harness for vehical was told the reason I have no sound is becuase the pink and black wire labeled Audio interrupt lead were does this connect 2
The install diagram indicates the Audio Interrupt wire goes to a Vehicle Phone. If you don't have one, don;t connect it to anything andmake sure you put tape over the end so it doesn't touch ground or a power source.
In cases where I don't have or cannot get a wiring harness adapter to plug directly into my vehicle wiring harness I have a trick I like to use. I don't like to cut and remove a vehicle harness socket, I may want to keep the aftermarket stereo when I sell or trade and put the original stereo back in place. Instead of removing the socket I skin back (but do not cut) the wires I need to tap into and wrap the aftermarket unit's wires around the now exposed socket wiring, then solder each one & wrap each one individually with electrical tape. This gives you a secure connection and when and if you need to permanently remove the aftermarket unit you just untape the wires, clip the fatermarket wires off one at a time very close to where they are tapped in, tape each one of them again and there you have the factory plug ready to plug back into the factory stereo.
Aug 20, 2011 | Alpine CDA-7892 CD Player
Need a stereo wiring diagram to reinstall factory stereo in my 93 toyota windom
You shouldn't need a wiring diagram, your factory plug should still be in behind the aftermarket stereo harness, unplug the aftermarket harness and your factory plug plugs directly into the factory harness.... hope this helps..
Sep 21, 2009 | Car Audio & Video
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
I need a wiring diagram for the aiwa stereo harness.
I would like to see a plug for a aiwa car stereo
Mar 30, 2009 | Aiwa CDC-X207 CD Player
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Mar 29, 2009 | Car Audio & Video
No harness plug that goes into the back of my stereo
go to ebay and search this exactly the way it is wrote. ISO Wiring Harness connector/adaptor for KENWOOD 12 Pin
Jan 12, 2009 | Durabrand Car CD Player and AM/FM...
Installing after market stereo
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Nov 21, 2008 | 2000 Pontiac Grand Prix
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
JVC KD-S680 CD Player Logo
1,308 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
