Question about Schwinn Airdyne AD6
I have a schwinn ad6 and the belt broke, how much belt deflection is normal when installing the new one?
2 Suggested Answers
ibm2065
  • 333 Answers
SOURCE: Schwinn ad6 ,just got but hard to get started,to much tension,is it a way to loosen it ?
Carefully mount the machine using the Foot Step Pad if necessary. Adjust the Seat and Pedals before starting a workout.
LowerBodyWorkout:SlowlypedalwithyourarmsrelaxedatyoursidesorwithyourhandsrestingontheHandGripsas
the Handlebars move.
FullBodyWorkout:GrasptheHandGripswithyourpalmsdown.PushandpulltheHandlebarsasyoupedal,keeping
yourelbowslowandnexttoyourbody.
UpperBodyWorkout:GrasptheHandGripsfirmlywithpalmsdownandplaceyourfeetontheFootPegs.Leanslightly
forward at the hips with your back straight and shoulders down. Now push and pull the Handlebars
Note: You may need to safely push a Pedal to assist with starting the workout.
To increase the air resistance and workload, increase your level of activity. Toexerciseallthemusclegroupsinyourarms,
alter your grasp to palms up for part of the workout
Schwinn AirDyne Pro Owner Manual Operations
Posted on Jul 07, 2018
The wire on my schwinn basic computer broke. Can I buy a replacement ?
It depends on where it broke. If it broke at the transmitter or computer, you're probably out of luck. Otherwise, you should be able to splice the broken ends together and have working as good as new.
Oct 04, 2014 | Schwinn Basic Computer
How do I change the drive belet
To remove a 2007 Touring drive belt FIRST remove the rear wheel and the rear swingarm, remove the primary chaincase assembly,remove the old belt from the transmission sprocket.
To install a 2007 touring drive belt FIRST install the new belt on the transmission sprocket, then install the primary chaincase assembly, then install the rear swingarm and the rear wheel and adjust the belt deflection to specifications.
Belt Deflection
Vehicle Orientation Model Inches Millimeters
Motorcycle Upright
With Rear Wheel in Air
or On Jiffy Stand
Without Rider or Luggage
FLHR/C,
FLHT/C/U, 3/8-7/16 9.5-11.1
FLTR
FLHRS,
FLHX1/4-5/16 6.4-7.9
Apr 27, 2014 | 2007 Harley Davidson FLHRC Road King...
How to install seat
Bicycle seats just slip over the vertical pipe into the pinch clamp. Tighten the clamp after installed. If the clamp is to narrow to allow it to slide over the pipe then loosen the bolt or remove it and spread the clamp apart a little then put it back together.
Apr 02, 2014 | Schwinn AD6 Airdyne Upright Exercise Bike
I want to know how to remove the alternator kia optima 2003
  1. Disconnect the negative battery cable.
  2. Temporarily loosen the water pump pulley bolts, 1.6L (VIN 3) engine only.
  3. Remove the front air intake inlet pipe bolts, 1.8L engine only.
  4. Remove the top hose from the air intake inlet pipe, 1.8L engine only.
  5. Remove the air intake inlet pipe clamp and the pipe, 1.8L engine only.
  6. Remove the power steering pump, 2.0L engine only.
  7. Remove the power steering pump bracket, 2.0L engine only.
  8. Remove the alternator B terminal cover cap.
  9. Disconnect the alternator electrical connections.
  10. Loosen, but do not remove the alternator pivot bolt and the tensioner mounting bolt.
  11. Remove the drive belt(s); relieve tension on the belt by rotating the adjustment bolt.
  12. Remove the water pump pulley, 1.6L (VIN 3) engine only.
  13. Remove the power steering pump, 1.6L (VIN 3) engine only.
  14. Remove the power steering pump bracket, 1.6L (VIN 3) engine only.
  15. Remove the alternator tensioner mounting bolt and the belt tensioner.
  16. Remove the alternator pivot bolt.
  17. Loosen the bolt at the base of the adjusting bracket and rotate the bracket up.
  18. Remove the alternator.
    Fig. Alternator mounting-1.5L and 1.6L (VIN 5) engine shown
    Fig. Alternator mounting-2.0L and 1.6L (VIN 3) engines shown
    Fig. Alternator mounting-2.4L and 2.7L engine
To install:
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Install the alternator.
  3. Install the alternator pivot bolt and hand-tighten at this time.
  4. Rotate the adjusting bracket into position, place the belt tensioner into position. Hand-tighten the mounting bolt.
  5. Install the drive belt.
  6. Adjust the belt tension by rotating the adjustment bolt.
  7. The belt deflection for 1.5L, 1.6L (VIN 5), 2.4L and 2.7L engines, is as follows:
    1. New belt: 0.22-0.28 in. (5.5-7mm).
    2. Used belt: 0.24-0.28 in. (6-7mm).
  8. The belt deflection for 1.6L (VIN 3) engine is as follows :
    1. New belt: 0.13-0.15 in. (3.3-3.7mm).
    2. Used belt: 0.17-0.19 in. (4.2-4.7mm).
  9. The belt deflection for the 2.0L engine, is as follows:
    1. New belt: 0.22-0.31 in. (5.5-8mm).
    2. Used belt: 0.33-0.45 in. (8.5-11.5mm).
  10. The belt deflection for the 1.8L engine, is as follows:
    1. New belt: 0.23-0.31 in. (6-8mm).
    2. Used belt: 0.28-0.35 in. (7-9mm).
  11. Tighten the tensioner bolt to 14-19 ft. lbs. (19-26 Nm) and the pivot bolt to 28-38 ft. lbs. (38-51 Nm).
  12. Connect the alternator electrical connections.
  13. Install the alternator B terminal cover cap.
  14. Install the power steering pump and adjust the power steering belt tension, 2.0L and 1.6L (VIN 3) engines only.
  15. Install the water pump pulley, 2006 1.6L engine only.
  16. Install the air intake inlet pipe and fasten the clamp, 1.8L engine only.
  17. Install the top hose to the air intake inlet pipe, 1.8L engine only.
  18. Install the front air intake inlet pipe bolts, 1.8L engine only.
  19. Connect the negative battery cable.
Feb 09, 2011 | 2003 Kia Optima
The belt broke on this unit...how do I install it?
Unplug the power cord or shutting off the circuit breaker. Remove the belt guard loosen the four bolts that hold the motor to the compressor frame. The holes in the frame are slotted to move the motor for belt tensioning. Remove the old belt by pushing the motor toward the compressor. Place the new belt on the pulleys and hand tighten the four motor bolts. Align the two pulleys with each other. Apply a little tension on the V-belt. Place the bar at the base of the motor and push the motor back using the frame of the compressor as the leverage point & deflect the belt downwards with your finger. You should have approximately ½ inch of free belt deflection. Tighten all four motor mounting bolts & check the deflection of the V-belt and the alignment between the pulleys again. Realign or re-tension as necessary. A correct fit will ensure proper operation of the air compressor. Replace the belt guard on the air compressor and reapply the power. Check the belt movement through the guard and for proper operation of the compressor by following the manufacturer's instructions.
Jan 07, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I need step by step instructions on how to install an alternator belt into a 1997 kia sephia. Also need a list of necessary tools
Welcome to FIxYa.com
GENERATOR DRIVE BELT INSPECTION
1. Check the drive belt and pulley for wear, cracks, and fraying. Replace if necessary.
2. Measure the drive belt tension with a tension gauge.
Tension lb (N)
3. Measure the deflection by applying moderate pressure (221b,[9S N]) midway
between the pulleys. Adjust if necessary.
Deflection lb (N)
Adjustment
1. Loosen the generator mounting bolt and adjusting bolt.
2. Deflect the generator to achieve the specified deflection.
3. Tighten all bolts and recheck the tension.
Replacement
1. Remove the A'C and PS drive belt, if equipped.
2. Loosen the generator mounting bolt and adjusting bolt.
3. Remove the generator belt.
4. Install the new generator belt and adjust it to specification.
5. Tighten all bolts to the specified torque.
Tightening torque:
Mounting bolt:
2 7-38 ft-lb (37-52 Nm)
Adjusting bolt:
14-19 ft-lb (19-25 Nm)
6. Install the AC and PS drive belt: if equipped. and adjust to specification.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 17, 2010 | 1997 Kia Sephia
I believe I need to replace the motor. My cooler started making a loud noise and then just shut off and now it won't turn on at all. I'm new to this and have to do it myself but I'm having trouble finding...
Hi!!
DISCONNECT POWER TO UNIT BEFORE SERVICING.
There is not much to it, to access the belt/motor, remove side panels, loosen motor base bolts and push motor inwards to relieve pressure on belt. (you have to do this even if the belt broke off in order to install the new one), remove old belt and install new one. Slide/Pull back to tense belt. Proper tension is achieved when push belt with your finger between pulleys and the deflection is about 1/2"
Good Luck!!! Don't forget to rate this post!!!
Aug 15, 2010 | Mastercool 67680 Evaporative Cooler Air...
I need a diagram on how to replace a 2001 chevy metro alternator.
2001 Chevrolet Metro 1.3L MFI SOHC 4cyl
Alternator - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Air cleaner assembly Alternator electrical connectors Accessory drive belt Upper and lower mounting bolts Alternator
To install:
  1. Install or connect the following:
    Alternator and the bolts, do not tighten the bolts at this time
  2. Install the alternator belt and adjust the tension until a deflection of 0.24-0.31 inch (6-8mm) deflection with 22 lbs. (10 kg) of pressure exerted when installing a used belt. On a new belt the belt deflection should be 0.20-0.27 inch (5-7mm) with 22 lbs. (10 kg) of pressure exerted.
    Alternator electrical connectors, then torque the alternator bolts to 17 ft. lbs. (23 Nm) Air cleaner assembly Negative battery cable
    Negative battery cable Accessory drive belt Alternator electrical connectors Alternator
To install:
  1. Install the alternator and hand-tighten the bolts.
  3. Install or connect the following: Upper alternator bolt to 18 ft. lbs. (25 Nm) Lower alternator bolt to 40 ft. lbs. (54 Nm) Alternator electrical connectors Accessory drive belt Negative battery cable
    Fig. Exploded view of the alternator-Metro and Prizm models
Hope thats help (remember rated this).
Feb 18, 2010 | 2001 Chevrolet Metro
How to check alternator, and how to replace it.
  2. Disconnect the negative battery cable.
  3. Temporarily loosen the water pump pulley bolts, 1.6L (VIN 3) engine only.
  4. Remove the front air intake inlet pipe bolts, 1.8L engine only.
  5. Remove the top hose from the air intake inlet pipe, 1.8L engine only.
  6. Remove the air intake inlet pipe clamp and the pipe, 1.8L engine only.
  7. Remove the power steering pump, 2.0L engine only.
  8. Remove the power steering pump bracket, 2.0L engine only.
  9. Remove the alternator B terminal cover cap.
  10. Disconnect the alternator electrical connections.
  11. Loosen, but do not remove the alternator pivot bolt and the tensioner mounting bolt.
  12. Remove the drive belt(s); relieve tension on the belt by rotating the adjustment bolt.
  13. Remove the water pump pulley, 1.6L (VIN 3) engine only.
  14. Remove the power steering pump, 1.6L (VIN 3) engine only.
  15. Remove the power steering pump bracket, 1.6L (VIN 3) engine only.
  16. Remove the alternator tensioner mounting bolt and the belt tensioner.
  17. Remove the alternator pivot bolt.
  18. Loosen the bolt at the base of the adjusting bracket and rotate the bracket up.
  19. Remove the alternator.
    0900c15280028419.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Alternator mounting-1.5L and 1.6L (VIN 5) engine shown
    0900c1528002841a.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Alternator mounting-2.0L and 1.6L (VIN 3) engines shown
    0900c1528002841b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Alternator mounting-2.4L and 2.7L engine
To install:
Jul 29, 2009 | 2002 Kia Spectra
Schwinn Airdyne AD6 Logo
54 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
