When do I use "a lot of" or "many" - Computers & Internet
I have a lot of credit cards. Will this affect my credit history in a negative way?
Having a lot of credit cards that have high balances or with a lot of credit can impact on your credit score in a negative way, although it does depend a lot on your credit history.
Aug 19, 2013 | Finance
Philips tv 29PT6807/94
Contact the authorized service center. They can provide you the original LOT
Aug 01, 2013 | Televison & Video
How to replacement lot
To replace LOT, you have to resoder it out from the circuit board, and note its number. Each type of LOT has a specific number, and that number should be used. Different numbers will have different winding confugurations, and secondary voltages. If LOT has got damaged, it is best for you to replace the Horizontal Output Transistor also. Normally when LOT gets a winding short inside, this transistor may alo get damaged, or get leaky. So replace it too at the same time. OK.
Dec 06, 2010 | Aiwa F2000 20" TV
My KSRS25ILBL03 side by side - the freezer has lots of frost, the bottom of the freezer if full of ice. I removed the ice (hairdryer), found the drain to the bottom pan frozen. Cleared that, & water...
main reason for lots and lots of frost is door seals not tight all round.look along the length of them to make sure and adjust by pulling/pushing into shape,also are the doors level???? would also cause doors not to be airtight.(adjusters/feet are under both outside corners).
Apr 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
I Need The Unlock Code For Build-A-Lot 2
  1. download in GameHouse
  2. install the Build A Lot 2
  3. type this code
build-a-lot 2 town on the year!
Jan 06, 2009 | Computers & Internet
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
