Question about Krups Coffee Makers & Espresso Machines
My Krups XN 3006 Nespresso Pixie lever stucks
Hi today I want to use it in the office, and I actually don`t exactly know how to use it. I turned it on, pushed the bottonm,and didn`t wait until the button stop flashing ...... After a while the pumper ran, but did`t pump any water, and no coffee ran out, I tried serval times still the same ! AND the worst thing is that the lever stucks, I can`t get the capsule out !!!! My god can anyone help me ??? Or I will have to pay 126 euro for a new one ........
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 21 Answers
SOURCE: Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Posted on May 08, 2010
SOURCE: Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Posted on Jun 09, 2010
SOURCE: Hi, My Nespresso LeCube doesnt
I had the same problem. First, unplug machine for two (2) minutes. Then re-plug and as on/off switch is flashing- press and hold large cup button for 3-5 seconds (no light should show/flash from this button while you hold it down. The on/off will continue to cycle through its normal startup, after it completes you should be reset to factory settings and good to go. Good luck to you, this maneuver saved me.
Posted on Sep 13, 2010
  • 4 Answers
SOURCE: hi, i cannot get water
You can download the instruction manual from various places online; the instructions for the automatic and manual versions are slightly different but you can find them here:
www.eirvik.is/gogn/L/m100.pdf
www.eirvik.is/gogn/L/m100_automatic.pdf
As a first step I would suggest checking that the water can get out of the tank (just touching it with your fingers (over a sink!) should let drips out). It not, try cleaning that. You could also try descaling it (as in the manual). By the way, if the machine is less than three years old and you still have proof of purchase the Nespresso club will honour the warranty and fix it free of charge; if not, give them a call anyway and see what you can get them to do for you.
Posted on Sep 02, 2011
Error 5B00 Canon Pixma MG6120 Printer
1. Turn off your color printer
2. Press and have the STOP/RESET button
3. Press and also hold Power ON key
4. While keeping the Power ON switch, discharge the STOP/RESET key
5. While holding still the Electrical power ON button, push two times the STOP/RESET switch
6. Launch the Power ON key
7. Wait until that show an "abandoned" information. It will definitely take about a moment.
8. When "still" appear, open the best cover to leave open the ink cartridges
9. Raise the cover for cartridge holder and also obtain both the and shade containers.
10. Gain the cover from container holder and switch off the printer
11. Gain the leading cover and also switch on the color printer again
12. After the laser printer activate, return the ink cartridges.
1. Push and also Have the STOP/RESET switch and stand by until this personal reboot.
2. Release the STOP/RESET switch the printer is actually restarting.
3. Wait for a few secs
Download Driver here
https://www.canonprintersdrivers.com/canon-pixma-mg6100-series
Oct 30, 2015 | Canon PIXMA MP160 All-In-One InkJet...
At&t cell phones
It is most likely a battery that needs to be replaced although some chargers will indicate that they are charging and will run forever trying to charge a dead battery. Don't know why the AT&T rep didn't know what was wrong. This is pretty elementary
Sep 21, 2012 | Motorola Mobility ATRIX Cell Phone
My R4 Is Only For Ver 1.4.3U I Updated It To Ver 1.4.4U I Didn't Know My R4 Won't Work What Will I Do?
My advise is don't use R4 at all. It is illegal and it might brick your dsi
Apr 03, 2012 | Nintendo Dsi XL
Interior condensation
I had this exact same problem when ever it rained with our 1999 Range Rover.
Even the spare tire area in the back filled up but didn't know it until I got a flat tire.
Two things were wrong.
The sunroof leaked and we didn't know it. Also the seal all around the frontwindshield was not sealed tight but didn't know as neither of these were obvious. We ended up using "duct tape all over the roof around the sunroof and I meen a lot of tape! It looked bad from the sky, however stopped leaking 100% Dont use the sunroof if you have one until summer, remove wet tape periodically and inspect. Hope this helps! :)
Nov 29, 2011 | Cars & Trucks
Don't know the product key
MY FRIEND INSTALLED M S OFFICE PROFESSIONAL 2007 IN MY PC. HE DIDN'T GIVE ME KEY TO VALIDATE IT. NOW I AM LOOKING FOR KEY.
Jul 31, 2011 | Microsoft Office Professional 2007 Full...
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I'm having trouble with Call of duty- Modern warfare 2. Hasn't ever been a problem until today. Once you get on to the main game menu a screen flashes up saying that it has incurred problems registering...
Don' worry. There is a major problem occurring right across the board at this very moment with the PSN Network. Some consoles are not synchronising properly due to an internal clock error and causing problems exactly like you describe. It is expected that Sony will soon have this resolved.
For a full breakdown please look at this FixYa Tip.
If the solution helps, please leave a vote for it. Thanks.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
I have 3 ipc codes what does ipc stand for 98 cadillac eldorado
IPC stands for Instrument panel control, here is a typical code repair flow chart, this is for example only and has nothing to do with your car..
P083 = 24x signal high.
P107 = Instrument panel control )IPC) to computer (PCM) data problem.
P137 = Loss of Automatic braking system (ABS) to Traction control system (TCS).
What you need to do is CLEAR all these codes from the computer and see which ones return.
Perform this test.
1. Ignition key ON. Engine OFF.
2. Simultaneously push and hold the OFF and WARMER (^) buttons on your climate control panel for 3 seconds and release them.
3. Diagnostic codes such as above will appear with the word HISTORY or CURRENT for each code.
4. The codes will stop when you see PCM?
5. Push and release the HI(^) button and you will see PCM DATA?
6. Push and release the LO(v) button and you will see PCM DATA?
7. Continue to push and release the LO (v) button until you see PCM CLEAR CODES?
8. Push and release the HI(^) button until you see PCM CODES CLEAR.
9. Turn OFF the ignition and wait 3 minutes and try and start the car. If the car starts and the light comes back ON, Turn OFF the car and repeat steps 1 thru 3 and let me know what codes you get and if they are HISTORY or CURRENT.
10. When you see PCM?, Turn OFF ignition key.
11. Let me know what codes you get and if they are HISTORY or CURRENT.
---------- FOLLOW-UP ----------
QUESTION: this is what happen when it did what you told me what to do.
P047 History,P107 History,No IPC Code, P83 History,P137 History, A047 Current, No Sir Codes, T072 History,No Russ, PCM?
ANSWER: You did not follow the directives correctly . If you had, You would NOT have any HISTORY CODES.
Try it again and follow these directives EXACTLY:
8. Push and release the HI(^) button until you see PCM CODES CLEAR. WAIT 3 seconds and then proceed to 9.
Aug 14, 2009 | 1998 Cadillac Eldorado
Coffee Makers & Espresso Machines Logo
93 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
