Question about The Office Equipment & Supplies
The cog that turns the black rollers to feed paper into the 309a is off the track. If I slide it back on, it still has a hard time turning the other cogs. How do I fix this? Cleaned all rollers.
    New Friend:
But how does it work?
Posted on May 19, 2017
Paper feed won't accept photo-quality paper - the paper feed action is not smooth - it will just about take 80gsm paper but not evenly and sometimes it feeds several sheets through at the same time. At the...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
Please rate this solution.
Mar 06, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Feed roller rotates but paper does not move (feed).... I cleaned the roller
Hi!
Sometimes this can be caused by worn out tyres on the rollers. Like car tyres they wear out over time & become 'slippery' & fail to drag the paper the way they should.
Replacement tyres can be ordered from HP for your specific printer.
It may also be the cogs that turn the rollers, or perhaps the spring load on the paper tray (the part that raises the paper to the rollers). If it's either of those problems, I can only suggest taking it to a printer repair agent or if it's still under warranty, give HP customer support a call.
Hope this helps :)
Nov 21, 2009 | HP PSC 2355 All-In-One InkJet Printer
1610 all in one.....won't grab paper
The feed roller was turning but the paper wasn't moving and so I kept getting an "out of paper message." The paper was actually getting caught on a small black piece in the back of the printer. I removed the black piece and the paper start to feed fine.
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.cf725f2.jpg
Jan 30, 2009 | HP PSC 1610v All-in-One Printer
Paper loading
Try this solution if this did not work then there is hard ware failure in the printer ...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 22, 2009 | Epson Stylus CX3810 All-In-One InkJet...
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Paper feed problem.
I have just removed the panel where the power and USB cable lock into. It's a case of 1 screww from the rear and 2 catchs underneath the printer. From there you should be able to see the mechanism for the roller, a set of small white cogs. below that you should be able to see a very small spring which is acting as the pressure. Mine was still attached but as you say was pulling no pressure on the roller what so ever.
Solution:
Find yourself a large-ish rubber band and slip the band over the whole mechansim. Best way is through the paper feed slot, slip it over the roller and then move it through to the area where you removed the panel. Position the rubber band as far down the cogs as possible, don't worry the cog casing prevents the band interfearing with the cogs. Now pull the band reasonably tight and with the other hand test the pressure of the roller. Adjust till you feel OK with it. Now put the panel back in with the end of the rubber band trapped and poking out from the panel behind the printer, holding it in place. Redo the screw and give it a try.
My first attempt found it a bit too restrictive and feeded to sheets at a time but adjusted it once and its back to normal. I know its a bodge but its a cheap one and it uses a rubber band, just how I fixed my Punto's windscreen wiper, £120 part or a rubber band once a month... Mmmm...
Jan 22, 2008 | Lexmark P4350 All-In-One InkJet Printer
Rollpaper feeding problem on R800 Epson
try to look at your rollers made of black rubber, if they are shining then they need cleaning, if you know how to open the unit to get to all these rollers then you might be able clean them yourself with laquer thinner and a rag, where gloves and turn the rollers into the soaked rag and keep turning tight with lots of elbow grease until all rollers lost that shine.
Jan 18, 2008 | Epson Stylus Photo R1800 InkJet Printer
Media Jam Fuser
I got that error turning off the machine in the middle of printing, opened the door to back, unlashed the 2 green tabs to the final heat roller towards the top and there was my page. i gently pulled it out error gone.
but in your case sounds like the paper is having a hard time feeding through all your rollers or the first one... in that case it has to torn down to the first roller and inspected for paper pieces , what ever, and I clean the rollers with laquer thinner rubbing hard on the black rubber until that high gloss is gone.
Jan 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Oct 11, 2007 | Office Equipment & Supplies
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
23 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
