Question about Samsung Televison & Video
How to fix the Samsung CS21C510CL CRT TV after switch on only one Sheree... Sound no picture and no sound but sometimes it's work good and
    Top Expert:
  • Samsung Master
  • 75,404 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on May 19, 2017
3 Suggested Answers
  • 43969 Answers
SOURCE: How to fix my Samsung cs21c510cl CRT TV switch on but no picture and no sound but sometimes picture & sound is OK, what is the problem.
The power supply may be failing.
Posted on Apr 08, 2017
  • 43969 Answers
SOURCE: How to fix Samsung CS21C510CL CRT TV switch on but only standby light blinking no picture and no sound.
Could be an open internal fuse or power supply failure.
Posted on May 18, 2017
How to fix Samsung CS21C510CL CRT TV switch on but no picture and no sound only standby light blinking five times and then after few seconds it's starting again and again blinking and so on.
hi .
You can try replacing the power supply card and the video card .sometimes the power supply section has bad capacitors that need replacement .
May 18, 2017 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
No picture, sound works on Sony TV KV-27V22.
try to adjust the screen. it is located behind the CRT board.(CRT board is the board that attached to the picture tube) you will find a black knob which label screen adjust it by turning the knob.
Jul 04, 2009 | Sony KV-27V22 TV
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
I get no picture on samsung pck5315r TV
no picture & sound ok as sound is there means your power supply &high voltage section is ok problem is in video section 1 crt is glowing or not if not check its supply. 2 check crt base or any connector for loose 3 check supply to video & crt base(g2) 4 check for video signal is coming to video sectuon from processor ic. 5 loose print if any. hope this will help
Sep 30, 2007 | Samsung PCK5315RX TV
Occasionally picture and sound out of order
have a tech resolder the circuit board it has an intermittent problem,which means that some of the components on the board has loose connections.causing the tv to operate sometimes.good luck.
Jul 01, 2007 | Samsung DLP HL-P5663W 56" TV
1997 samsung tv problem
your tv needs to be repaired call a tech.the tv has a defected power supply or related circuit.good luck
Apr 10, 2007 | Samsung TXG2547 25" TV
Open Questions:
Televison & Video Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
