Rascal turnabout Key simple flushes seven times ?
Not sure about model number
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
All 'Rascals' will behave the same. No wonder.
Posted on May 19, 2017
Curtis pmc 1208-2413 schematics
The older control boards can be repaired. Email me, the rebuilder is the only ones with real prints, because they used to work for Curtis. they warranty their work and I have never had one of the rebuilds fail. new those controllers were$480, rebuild maybe half of that but they warranty it longer than original. So another option is up dating the old system but that is like $800, the question just came up with a customer last week. Scooter Doctor App
Sep 07, 2014 | Electric Mobility Rascal Scooters,...
I have a Rascal 200..was working after you go forward and let go of the throttle. goes in reverse itself. .is there a throttle adjustment?
I had a similar problem on my Pride Legend scooter, it would
creep back in reverse if you let go of the throttle. The FWD/REV spring tensioned throttle pot inside was "off center"causing it to activate in reverse when it should have stayed put with the electric brake energized.
I had to replace the throttle pot assembly. Not sure if yours
is similar, but I would suspect it might be.
Jul 29, 2014 | Electric Mobility Rascal Scooters,...
Rascal scooter
Could have a wiring issue you should look in the console make sure nothing is crossed.
Jul 21, 2014 | Electric Mobility Rascal Scooters,...
Sometimes my electric mobility scooter acts as though it's dead - but, the batteries are fully charged and the horn will work. Other times, it acts perfectly normal. The downside is, it's left
okay now this is most likely a loose connection
does the rear axle come away from the main frame ? if so check the connectors there clean gently,,,,
Now check the battery connections does the battery pack come away from the scooter if so again check the connections here , clean and make sure connections are good.
Jan 12, 2013 | Electric Mobility Rascal Scooters,...
Rascal liteway 224 scooter
Hi Allen,
The problem is that although it is physically in neutral, the safety switch for indicating it is in neutral is not working correctly. It could be the switch itself or the wire(s) from the switch. Get a manual and see if you can trace the wires from the neutral switch.
Aug 06, 2012 | Health & Beauty
HELP ! My Rascal joystick has option to raise & lower height of chair; I raised it to get in my freezer and now it will not lower. When it is in the RAISED position, the speed is less than a ONE a
This device either is hydraulically operated or operates use a motor and jacking screw, which is much more common. Take the seat off the jacking post. Put a piece of wood on the top where the seat was mounted. It should make the same kind of motor noise going down as it makes going up. If it never made noise going down it probably because its a hydraulic system so the down button activates a valve opening a hydraulic line allowing fluid to flow out of the chamber holding the piston up that your chair is mounted on. If it did make the same kind of noise going down, its a screw jack type mechanism. In either case hit the top of the wood once with moderate force. I like using a 5 pound hammer. I call it my master calibration tool. Make sure you strike the top of the wood piece straight down in order to avoid bending things. Try operating it now sometimes things get stuck when moved to their limit. So push the reverse button, then tap the piston down. You can check to see it the motor is getting voltage you will need a 24v circuit tester
I would like to see pictures of his devise. Any tag or stickers with who made it, model number?
Jul 28, 2012 | Electric Mobility Rascal Scooters,...
Rascal turnabout key picture has flashing red light ...scooter wont move
Take a magnet and touch the key symbol on your control.This will unlock it.
Apr 13, 2012 | Amigo Health & Beauty
What rascal turnabout battery is ?how much is ? and how can i buy it ?
It needs 2 U1 batteries the cost can be from 70.00 to 100.00 each and I would check for an interstate battery dealer or if you can find a battery warehouse type store they should carry these
Hope this helps
Oct 26, 2010 | Health & Beauty
Wiring diagrams for Rascal turnabout
Metz the only place I could find that might be able to help you is the Manufacturer. You can call 1-800-MOBILITY, that's 1-800-662-4548 to see if they will send you the diagrams. Hope this helps you
Sep 21, 2010 | Health & Beauty
Televison & Video Logo
Top Televison & Video Experts
