Question about Pool & Spa
Brown SLE 2 gas heater and it has no remote - Pool & Spa
    Top Expert:
  • Pool & Spa Master
  • 7,200 Answers
Go into system set up and put into remote if no setting see if controller has heater plug add to firemans switch and turn heater all the way up
Posted on Oct 30, 2017
Why are a/c and heat not changing when I move the temperature up or down just on the driver side?
GMC Acadia no heat coming from heater Questions ... - Fixya
www.fixya.com > ... > Cars & Trucks > GMC
GMC Acadia cars & trucks no heat coming from heater questions and answers. ... on my GMC Acadia 2008 SLE the panel where i control the AC/Heater stopped ...
Sep 09, 2015 | 2007 GMC Acadia SLE
Why do I get an FL5 error what is the problem.
shows brown out means the display board is bad replace it
May 21, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Heater stopped firing up to achieve temperature. No gas release
when firing see if voltage to gas valve brown wire should be 24 volts ac if voltage bad valve if no voltage check safety circuit
Aug 31, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
250 lite 2 does not come on flashes f 5
bad display board replace if you can find one
Aug 17, 2012 | Jandy Digital Lite2 Lj250 Btu Heater,...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
2003 gmc seirra sle 2500hd 4x4 ext'd cab duramax diesel allison a/t #1 heater fan operates on hi w/switch on hi when engine is started, but will not in most cases when adjusted after engine is running???...
To reset the oil life......turn the key on....do not start....pump the gas pedal 3 times within 5 seconds.....then turn the key off and back on and it should be reset....sometimes u have to do it a couple times.......and what heater fan r u talking about?.....
Dec 30, 2009 | 2003 GMC Sierra
GMC Sonoma SLE 4.3L 1991- Coolant Temp Gauge Not reading
there are 2 coolant sensors one for gauge and one for ecm
Jul 23, 2009 | 1991 GMC Sonoma
Pool & Spa Logo
104 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
