Question about Symbol Computers & Internet
Key symbol flatteries seven times - Symbol Computers & Internet
I have a Wolf cooktop model CT36E/S that has the burner lock key flashing. I tried shutting off the breaker many times. PLEASE HELP!!!! Model. CT 36 E/T Serial 11040943
way late but if not fixed here ya go...
Look in the bottom right corner of your Wolf cooktop. A key symbol glows when the cooktop is locked. Press and hold the glowing key symbol for three seconds. The cooktop emits three chimes and the symbol stops glowing when the lock is switched off.Hold the key symbol down for a further three seconds to reactivate the lock.
Jan 20, 2018 | Cooktops
How to make cent symbols with windows seven
  • Press and hold the "Alt" key and type "0162" using your computer's numeric keypad
  • Jan 10, 2013 | Computers & Internet
    Every time I press the F & J key I get an underscore or @ symbol; then when I press the V key I'm getting the symbol as if the CODE button was on...help!
    you are probably in KBII mode Brothers usually have letters above the top row of keys code and KBII should bget you out of it.
    DickyO
    Jul 31, 2012 | Brother ML-300 Typewriter
    How do I insert a symbol eg '!' ?
    Depending on your cell phone brand. Sometimes its shift first then the symbol. On the one I have now its "FN" key in which the "FN" key is brownish in color after you press that then any key that has a brownish color symbol on it can be pressed and you get that symbol. This method only allows one symbol at a time unless you press "FN" key again. I hope this helps you.
    Jan 06, 2012 | Cell Phones
    My friend bought me a hyundai egg cooker(plu 247959) but the instructions only tell you how to soft boil 2 eggs or hard boil 3! and no instructions of other amounts of eggs or how much water to use or how...
    Ignore the instruction manual. Instead look at the measuring cup that comes with your Hyundai PLU 247959 (produced and sold under license by Poundstretcher).
    On the side of the measuring cup, you can see three clusters of marks:1. 25 to 40 ml for soft-boiled eggs (symbol of egg with two horizontal lines)2. 45 to 60 ml for medium boiled eggs (symbol of egg with one horizontal line)3. 65 to 80 ml for hard boiled eggs (symbol of egg)
    Egg boilers are based on the principle that the larger the volume to be heated is, the less water is required. In other words, you will need to add less water for boiling seven eggs, and more water for boiling one or two eggs.
    Which means that for seven eggs to soft boil, add 25 ml; and for one egg to soft boil, add 40 ml. If you look at the markings, you'll notice that on the vertical line between 40 and 25 ml, there are seven equidistant horizontal lines, each showing the amount of water required for the various quantities of eggs.
    One egg = fill with water up to the 40 ml markTwo eggs = fill up to the mark below the 40 ml markThree eggs = fill up to the second mark below the 40 ml markFour eggs = fill up to the third mark below the 40 ml mark etc, untilSeven eggs = fill up to the 25 ml mark
    Medium boiled and hard boiled eggs are measured in similar ways. Works every time for me. Nice little egg boiler, by the way.
    Oct 09, 2011 | Back to Basics TEM-500 Egg & Muffin...
    Express 0 000 000 678 in scientific notation Problem
    If you want to see 0.000 000 678 as scientific notation, it would be 6.78 x 10^-7
    But since your original number did not contain any decimals, you might have meant 0.0 000 000 678, in which case the answer would be 6.78 x 10^-8
    The symbol ^ stands for "to the power of". So the first example would be pronounced Six point Seven Eight times Ten to the power of negative Seven.
    I hope this answers your question!
    Aug 01, 2011 | Computers & Internet
    The screen says please point the image's center area correctly when you turn gps on. can this be fixed?
    The screen shows a plus point with this message.Just click the plus symbol.It moves to somewhere else in the screen. Again press the point continuously till the point disappears. Normally six or seven times.Then the system start works.
    Apr 02, 2011 | Sylvania GPS
    Cannot play DVD's of region 2. Need unlock code for PhilipsAZ5738
    Press setup, go down to the lock symbol. do not enter it, just have it highlighted, then press "0" seven times. this will make it region free.
    Nov 04, 2009 | Televison & Video
    Accessing divide symbol on T40
    To access the euro symbol on the 4 key, press the "Alt Gr" key + the Number "4" key together at the same time.
    Jul 08, 2009 | IBM ThinkPad T40p 2373 Notebook
    Computers & Internet Logo
    18 people viewed this question
    Top Symbol Computers & Internet Experts
    Michael
    Oloyede Monsuru
    Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
