Question about Water Heaters
Where can I perches a remote control unit for my Brown SLE 2 gas heater
2 Suggested Answers
  • 120 Answers
SOURCE: Model RE2424 W-Z (SP) one the
Disconnect both controllers. Put the one that works ok on the wiring supply to the one that isn't working. If it does not work you have a wiring problem. If it does work then the controller is faulty. This wiring is 12volt low amps by the way. When connecting the wiring can go either way on to the back of the controller. Don't let the two wires touch if the power is on to the heater, this can blow the circuit board on some older models.
Posted on Aug 20, 2010
Main remote control is not working can you bypass the remote temporarily
No. However you may be able reset the thermostat to its factory setting.
Turn the thermostat off.
Shut of the gas and water supply to the unit.
Unplug or disconnect the unit from its electrical power source. Disconnect the thermostat from the heater.
Wait approximately 5 to minutes, and then reattach the thermostat wires to the heater.
Turn the water supply on and open the tub faucet to its hottest setting for about a minute.
Turn the faucet off and make sure no water water is flowing anywhere in the house.
Turn the gas supply back on.
Reconnect the thermostat wires to the heater.
Connect or turn the power supply back on.
Wait at least 2 minutes before turning the thermostat power button back on.
After the thermostat power button has be pressed, wait an additional 2 minutes before running water.
Test the heater at this time. Turn the water on at the farthest faucet to its hottest setting. measure the temperature with a cooking thermometer.
If you need to make adjustments to the water temperature, either up down, shut all the faucets off first.
The thermostat should read 100 degrees Fahrenheit when it first starts.
If you are receiving an error massage, consult with the manufacturer.
If the thermostat is reading the correct water temperature but the unit is not operating, there are other issue need to deal with. Let us know if this works or you need further assistance.
Sep 26, 2010 | Rheem Tankless Water Heater Main Remote...
Tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
on Dec 01, 2009 | Rheem Tankless water heater for 1-2...
Model RE2424 W-Z (SP) one the 2 remote controllers is not displaying any power lights or 2 digit display. The other unit still works and the heater unit is functioning ok. Would like to get the other...
Aug 05, 2010 | Rinnai Digital Remote Water Heater Control...
EcoSense by 4.2 GPM Tankless Water Heater LP Gas: I need to extend the wiring on the remote so it ca...
Always shut down anything electrical low voltage or other BEFORE attempting anything. The two wires attached to the remote can be extended with longer wire and wire nuts. If you look at your owners manual it will tell you that you can hook up additional controllers (up to four I believe) and have one in each bath, at the kitchen and at the unit. Pressing the priority button at whatever remote you are at will make that remote control new temps to unit and display at all remotes.Don't get crazy with too many wire nuts!
May 16, 2010 | Rheem EcoSense by 4.2 GPM Tankless Water...
Remote control unit flashes 76. No buttons on the remote will function. Water heater will not come on when there is a demand for hot water. Any suggestions?
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
If this helps, please indicate so.
Mike//jzklipper
Nov 25, 2009 | Rheem Rtg53xn Natural Gas Tankless Water...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rinnai tankless water heater. gas will not ignite automatically . have to bleed gas screw on heater every time.
CHECK THE AMOUNT OF PRESSURE COMMING IN TO HOUSE, MIGHT HAVE TO CHANGE THE METER, OTHER GAS ITEMS IN THE HOUSE ARE STARVING THE UNIT AND TAKING FROM IT
Apr 14, 2009 | Rinnai Digital Remote Water Heater Control...
I keep getting error code c4 76
You are having a communication fault with remote control...........#1...Check remote control wiring for loose or damaged connection. #2-Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Repalce caable if found to be faulty #3- Repalce remote control and #4- replace the PCB. These are items connected to your problem....it may be anyone of these....Good Luck
Apr 11, 2009 | Rheem Tankless Hot Water Heater...
No hot water from tankless water heater. Bliniking Readout
http://www.rheemtankless.com/content/tankless/rheem/help.shtml
This is there website.Above.
Use the live chat to ask them, the code you listed does not seem to correspond to there code list, the only code that does is code 76,
which is a problem with the remote control not talking to the unit.
So your best bet is to tell them the error.
Apr 07, 2009 | Rheem Tankless Water Heater Main Remote...
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
