Question about HP Garden
I have an older 10 hp b&s eng in a gen, eng no243431 0617-11 7511201. I need to know what model to order parts, get spec etc like the magneto air gap. regards glen thorburn & thanks
    Master:
  • 450 Answers
For the magneto, the rule I always used was put a standard thickness business card between it and the flywheel and tighten it down, then remove the card. This leaves just enough clearance.
Posted on May 19, 2017
DMPKJTW7F182
it is an Ipad 4th generation (WiFi only)
Lookup Mac Specs By Serial Number Order Model EMC Number Model ID EveryMac...
iPad 4th Gen (Wi-Fi Only) 1.4 GHz* Apple A6X apple-ipad-3rd-gen.jpg Intro Date: October 23, 2012* Disc Date: October 16, 2014** Order No: MD510LL/A* Model No: A1458 (EMC 2604*) Subfamily: iPad 4th Gen (Wi-Fi) Model ID: iPad3,4 Std RAM: 1 GB* Std VRAM: None Std Storage: 16, 32, 64, 128 GB* Std Optical: None Complete iPad 4th Gen (Wi-Fi Only) Specs
Aug 25, 2014 | Apple iPad Tablets & eReaders
Hi i would like to know why do i only have fire on one side of my 23 hp kawasaki motor?
Assuming that you have checked the spark plug and confirmed that it has not completely failed, the most common reason is the magneto on that side has failed. (There is a separate magneto for each cylinder).
To replace a magneto, you'll need to look up which part is used on your particular engine. (You will need the brand (Briggs, etc.) and the complete engine model and type numbers from the id tag on the engine).
Then go to an intrernet parts seller and look up your part number. One place you can start at is at PartsTree
http://www.partstree.com/parts/
Once there, click on the engine icon for your engine and drill down until you find the correct magneto part number.
Replacing the magneto is simple, removing the top engine sheet metal cover involves removing a few bolts, and both magnetos are then readily available.
When installing the new magneto, you first screw it down at the furthest point away from the flywheel. Then rotate the flywheel so that the magnet is aligned with the new magneto.
As part of the new magneto, you will get a thin sheet of cardboard that you hold against the flywheel magnet and loosen the new magneto, allowing it to be pulled again the magnet (with the special cardboard spacer in between).
Use care as the magnet is quite strong and the magneto will be pulled to it with a strong force.
Now firmly tighten the two screws that mount the new magneto and slowly rotate the flywheel to remove the cardboard. Replace the engine top cover and your done.
May 24, 2014 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Mountfield 1228h ride on mower battery does not keep charge when mowing
had same problem,when u r setting in the sit open the hood of the tractor on the left side of the eng. u will see a square part bolted into the side of the up by the top it should have three wires coming out of it this is the rectifier which runs off the magneto on the eng. this keeps the battery charge but very expensive $57 had to order mine from craftsmans took 1wk
Mar 31, 2011 | Tecumseh Ov691ea 22 Hp 22hp Lawn Rider...
Have a 5600 Gen. with 10 HP B/S engine OHV. Did great during Rita, replaced carb- changed gas-replaced plug- doesn't want to fire it seems. Where Can I find the magneto ? Are there points on the flywheel...
The magneto is by the flywheel. Depending on the age, there maybe points under the flywheel. If so you remove the flywheel and there the points are. Sometimes bugs build cacoons between points, make them inoperable. Newer engines have electronic ignition though. Follow the small wire from the magneto coil ( where the spark plug wire goes) it will either go under the flywheel through a plastic bushing, or to an electronic module. The magneto coils do fail you can test with an ohm meter. Before that test for spark. You can remove the spark plug, and let it rest on the engine to get ground, and turn the engine over. You always need 1-spark, 2 fuel . If you have spark, see if it will hit on starting fluid, if it does, then you have a carb or fuel filter issue. Those shut off valves on the bottom of those tanks, can be a problem
Jun 29, 2010 | Briggs Stratton H7159 & Stratton® 5500,...
Engine speed & frequency specs
most gen sets are set at 3600 rpms at 60 hz
Oct 11, 2009 | Electrical Supplies
I want to know which generation is the Ipod 30G model A1136, thanks
There are two 5th gen iPods, A1136 model is the older 2005 model, not the later 2006 model.
Here is Apples link: http://support.apple.com/kb/HT1353#ipodfifth2 which will show the differences, but not by model number. The reason I know this model number is the first 5th gen 2005 is because I have one. Also older 2005 should have '2005' engraved on rear.
May 29, 2009 | Apple iPod classic 5th Generation
Briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Jan 16, 2009 | Briggs Stratton H7159 & Stratton® 5500,...
Valve spring broke
Not sure but I think someone told me it is a knock off of the Honda? If so maybe try comparing? Ck size, Spring tension & etc?
I know not much help but that's where I'd start. Been told by a local small eng shop there aren't internal parts available for the Sumec engines.
Mike
Dec 09, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Garden Logo
Top HP Garden Experts
Vernon Taylor
michael vanier
Are you a HP Garden Expert? Answer questions, earn points and help others
