Question about Car Audio & Video
I cancelled my DSTV Subs in April and my debit order still went off.WHY?? only paying for the little silver box and not decoder subs....moved in with daughter. Lynette Brockway 083 780 5566
zoomiezz
  • 50 Answers
SOURCE: spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Posted on Feb 25, 2009
  • 398 Answers
SOURCE: popping sound! please help - jl 500/1 and two jl w3v3 2ohm subs
no connection are good + to + -to - thats all that matters. either the speakers are blown or you need a stronger amp. since you already tried speakers probably need bigger amp. definitley not the box. no such thing as a break in period, are the subs 10 12 inch or what. you could try to bridge them too that means hook both up to the same +-terminals, 2 wires per screw. it usually isnt the way they hook them up, its the wires fuses etc that cause problems. what guage wires is the speaker wire, the power line etc. if you give me these guages i might be able to get somewere
Posted on Feb 27, 2009
artbesio
  • 55 Answers
SOURCE: 5 stage band pass sub box, 1 sub stolen, box built to spec subs
I would try walling it up unless you are going to buy 2 brand new subs. the problem is the older power subs had such small magnets so they needed alot less air space inside the box. Unless you can find the EXACT subs this box was made for I would recommend chopping it and doing a single sub. if you try a replacement sub go with the 12" P1 series they are a close match for the power 12's of the past.
Posted on Mar 08, 2009
etirbynnor
  • 655 Answers
SOURCE: Specs for Ported Box for 2 12" MA AUDIO HK12X2 Subs
Hello joseph_delac,
MA Audio's website has the recommended box volume and port size online here. A ported enclosure needs 3.0 CuFt of internal volume and the port should be 48 sq/in and 14.5" in length. A 4X12" rectangular port would give you the recommended 48 sq/in. Using 3/4" MDF, a box 16X18X25 has an internal volume of 3.25 CuFt allowing .25 CuFt for the sub and port displacement.
Hope this helps.
Posted on May 13, 2009
  • 12 Answers
SOURCE: Need to connect my DSTV decoder through my sony
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Posted on May 03, 2010
Please cancel my Lovefilm subscription have not received any films because list ran out and do not wish to continue but have been paying subs for nothing.
why post this here?? we cant cancel anything here for you. looks like youll keep on paying for nothing i guess.
Oct 04, 2017 | Computers & Internet
How do I wire two subs up for the full 850 rms on a kac-9102d amp
  • Wire up two 4 Ohm subs in parallel (bridged) or one 2 Ohm sub.
  • You will take both of your subs positive leads and run them to the left positive (white connector on the amp) and both of your subs negative leads and run them both to the right negative (gray and black connector on the amp). That's max RMS right there. Pay attention to the Ohm rating of your subs as this does play a factor. What I explained is how to bridge two 4 Ohm subs. 8 Ohm is a little different but car subs rarely are 8 Ohm.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Kenwood KAC-9102D Car Audio Amplifier
I'm buiding a subwoofer box. i have 2-12
Well, good luck sir. Your'e going to have a lot of cancellation and possibly some blown speakers out of al of this unless you actually build a box around the back of all of the speakers. the subs are fine but there will be issues with the speakers. Either way figure out your own loads of all and have 1 2 channel amp for the speakers or multi channel for the speakers and a mono for the subs.
May 22, 2010 | Car Audio & Video
Wondering if non soldered terminals will cause subwoofers to cut in and out...amplifier turns on and stays lit green but subs cut in and out...have had amp and subs switched over from another vehicle in...
You're right; The clip-type or pinch-terminals could have just enough wiggle room to break connection when the box vibrates....causing the In & Out scenario.
You mentioned that the set (amp & subs) were mated in another vehicle, so there's little doubt that the subs are under-rated for the amp, right?
No chance that the sub-level adjustment was cranked up during the move, causing the aging subs to wash out...and you triple-checked the polarities,right?
Mar 28, 2010 | Sony TA-FE370 2-Channel Amplifier
I hook the hifonic amp up and it cuts on but the subs dont beat but the subs work
Try switching around one of the pos/neg speaker wires (you may have one crossed and they are firing out of phase, meaning when one pushes out the other pushes in and vise versa causing the base signals to cancel each other out) while the system is playing, only switch one speaker,not both. You can normally look at the subs and tell if they are moving very good and not much bass is there, you could also have the wrong box for them, this will also give a similar result
Nov 01, 2009 | Hifonics Generation XI Thor Car Audio...
My subwoofers ''fight'' each other
YOU ARE CONECTING ONE OF THE SUBS ON THE INCORRECT MODE SO DISCONNECT ONE OF THE SUBS AND SWAP THE WIRES AND TRY.
Mar 23, 2009 | Car Audio & Video
My amp wont power both subs the same
you most likely mess up you wiring... im not sure what ohm resistance your subs are, but if its 2ohm or 4ohm you wire straight foreward one sub all positive wires to left positive, all negitive to left negitive, and the same with sub 2 to the right terminal. BUT if your subs are 8ohm then wire it with all positives from both subs to LEFT positive and wire all negitive wires to RIGHT negitive... and see if that helps and good luck!
Jan 12, 2009 | Pioneer TS-SWX310 Car Subwoofer
Subwoofer Trouble
Turn the bass gain all the way down., Turn up your your volume on bass test song. Crank up the little box next to the steering wheel wide open . Now go gradually turn up the bass gain on the RF amp until you get distortion. Turn the gain down slightly. Now you can enjoy playing the bass from one end of the little boxes setting to the other without ovrloading your amp and subs. Open a can of whoopass on anyone who tries to crank up on your gain.
Nov 09, 2007 | Car Audio & Video
My amp works but my sub doesn't...!!!????????????
Whats the condition of your amplifier? New , Used, Old?
You might have a blown channel off your amplifier, this may cause little or no sound. You will have some distortion, crackle sound and then maybe nothing at all. What kind of subs are you running to it? Make sure the subs arent blown and check the voice coils to see that they are not torn off the subs , these are the 2 little silver or copper wires that are connected from the speaker connectors to the sub itself.
Let me know what happens?
Oct 21, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
