Promax combi 28 he plus no HW or ch blur fires then cuts off .keeps trying to fire but flame does not establish
SOURCE: Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Posted on Apr 28, 2009
gary1121
  • 332 Answers
SOURCE: Water Heater Won't Fire up
does the fan come on? this has to happen before it will even try to start if it doesn't your problem goes farther into the unit,, normal pracess if the fan then the ignitor then the flame, It could be in the circuit board most people that have gone with the tankless don't clearly ask the question but that is normal, but if you could clearify the procedure of what it is doing to this point i could be more helpful to you---- e-mail me what is happeing diffrent then what it use to do gary1121@aol.com
Posted on Jun 11, 2009
  • 13 Answers
SOURCE: I have a britony combi se 80. It keeps cutting out, error 60.
hi mate if you are happy to open the appliance and not disturb any gas connections clean the rectification probe, cause if its a intermittent fault it could be carbon deposits on the probe also make shaw the lead from probe to pcb is connected and not damaged if all ok its the pcb, let me know
Posted on Sep 12, 2009
Obertelli
  • 3006 Answers
SOURCE: Combi Boiler gives CH but not HW
Combi boilers have many moving parts compared to conventional models so must be serviced annually to prevent breakdowns.
Your boiler most likely has one of four problems:-
1. When the receiver for the wireless thermostat was fitted, other wiring was loosened and has come adrift. It's a possibility, but in my experience unlikely as the wiring involved isn't anything to do with HW supply..
2. During receiver fitting the pcb suffered a static electricity surge. Possible, but unlikely as this sort of damage is usually immediately evident. However, boiler pcb's are notorious for sudden failures anyway and can happen anytime. Combi pcb's are more prone to fail as they usually have up to four solenoids fitted and these do eventually fail due to mechanical wear.
3. When you your combi is in CH mode it heats the primary water circuit and directs the flow through the CH heat exchanger. When you open a hot tap (US=faucet) you're opening a supply of cold water initially as there is no stored hot water like in a conventional system. As the water starts to flow through the combi's diverter valve there's a pressure drop which activates a rubber diaphragm with mechanical connections to other parts. The diaphragm is one part which is routinely replaced annually as it will eventually fatigue and fail with the symptoms which you describe. In addition, the mechanical parts connected to the diaphragm pass through various seals in order to activate at least one micro switch. If the seals fail then the moving parts eventually corrode and seize up. Regular servicing prevents this. Combi seizures are a very common complaint in hard water areas.
4. One of the micro switches activated by the diverter valve has failed. Possible, but not likely. The purpose of the switches is usually to fire up the boiler to provide HW when the CH is not currently running, but as you haven't said which Vaillant you have I can't be definitive on this.
One major problem with combi boilers is that multiple failures can and certainly do occur almost at once. Unmaintained units may appear to be correctly functioning but in reality a number of worn parts can be close to failing. When one part fails, the others can't cope with the stress and fail as well.
In most civilised countries including the UK it's a criminal offence to attempt most repairs yourself unless you're qualified to work on gas appliances, so you need to find a decent heating engineer to service your boiler (ask your new neighbours). In the UK you can expect to pay around £120-£150 annually for a routine boiler service. If the circuit board has failed then it can easily add over £100. If parts inside the diverter valve/manifold have seized then you can be looking at an additional £80-£150. Note that diaphragm failures on their own do not merit diverter/manifold replacement and that if you have a new diverter fitted then a new diaphragm will already be present inside.
Dishonest heating engineers always diagnose a failed pcb as they know that you have no way of knowing whether it's true. If you can live with the problem for a few days then failed pcb's are usually a straightforward repair and there are plenty of companies who will send you a guaranteed exchange unit for much less than the cost of a new one. As long as you are not opening the main boiler casing which houses the combustion chamber and gas valve assemblies then some territories allow non gas qualified replacement, but others insist that the work is done by a qualified electrician: this is not the case in the UK as long as the pcb is not connected directly to mains electricity (no modern domestic ones are).
Posted on Oct 13, 2009
SOURCE: vokera boiler having to press reset button all the
could be the gas valve needing adjusted or the condensing pipe blocked
Posted on Jan 14, 2010
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Nov 06, 2012 | Heating & Cooling
My lynx boiler is good on HW but no CH, what can I check for
Check pump is working , is diverter valve moving over to ch , is stat turned up is clock set on ch, is there air in the rads , is header tank full in loft if fitted , is boiler presssure right if a combi .
Sep 11, 2011 | Heating & Cooling
My Rheem furnace fires up but the fire keeps cutting
Hi check out the pressure switch ,jump it out see if it fires clean flame senser if fitted, clean airfilter check fan afc is clean might be dusty
Feb 02, 2010 | Heating & Cooling
Oct 13, 2009 | Water Heaters
MicroGenus27 No Hot Water
check HW and CH temperature probes check secondary heat exchanger for blockage check water pressure switch
Jan 03, 2009 | Combi Centre DX - Mango
Bloggett Gas Combi
either the flame sense isnt sensing the flame or the heat board is bad.go to the second burner and you will see a probe,clean it up with sandpaper and see what happens let me know
Jun 06, 2007 | Blodgett BC-14G Gas Single Oven
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
