Question about Sharp Lands Phones
How To hard reset Aquos SHARP IS13SH
I have lost the password to my Aquos phone i cant soft reset
  • 13433 Answers
SOURCE: Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Posted on Jun 25, 2008
  • 7 Answers
SOURCE: how to update soft ware on my blu ray dvd sharp aquos bd-hp20
here is the link for Sharp BD and follow intructions that are with the file
Posted on Apr 26, 2009
SOURCE: Cannot hard reset XDA orbit - Forgot password
To perform a hard reset
1.Press and hold the Left SOFT KEY and the Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom center part of your device.
2.Release the stylus, but continue pressing the two soft key buttons. Release them only when you see the following message on your device screen: "Press SEND to restore factory default, press END to quit."
3.Press on your device.
On my XDA the reset button is located on the left bottom side of the XDA.
Posted on Nov 04, 2010
  • 2148 Answers
SOURCE: I want to reset my
I thought that *#7370# code does not work in 2730.But here Open Menu>>Setting>> Restore Factory Setting....and after this there are two 1. "Restore Only" 2."Restore All".Restore Only is to restore phone setting to default and Restore All is a kind of Format, it will erase all the phone's data. For your Security Code I do not know what you have done but here let give you one.
1. Downoad [ANT] Simple Ant
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel.
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
And for details How to Generate Your Phone Security code..Only for Nokia bb5
Thanks For visiting Fixya.Good luck
Posted on Sep 21, 2011
  • 174 Answers
SOURCE: how to hard reset a samsung wave 2 , lost password
Try Samsung default codes or get a rest code from nearby shop or online.
Posted on Jun 22, 2012
How do you do a soft reset on a Sharp Aquos
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 03, 2016 | Sharp Televison & Video
How to hard reset my blu 5.0s
how do I get the password in my phone , I cant get in it, I lost the password
Feb 21, 2016 | Blu Cell Phones
Lost the remote for my sharp tv. And the control panel is locked. Who do I unlock the control panel with out the remote?
If the problem you are having is that the television's operation lock out for the buttons on the tv has been enabled then the only way to undo that is with the Sharp remote control. The only work around I can think of is to perform an INIT, which is a factory reset. I do not know is Sharp customer service will still walk you through that over the phone because it is a detailed and dangerous (in that it can wipe the memory of your television if done improperly) process. I do not know what type of Sharp you have i.e. aquos or non aquos. 800-BESHARP is the number for non aquos support and 877-332-7867 is the number for aquos support (open 24 hours for aquos support last I checked)---32 inch and over aquos that is.
Aug 20, 2011 | Televison & Video
I have forgotten my password for htc p3300 how to unlock it
you need a hard reset. your all user data will be lost.
Hard reset:
1. power off phone
2. hold 2 soft keys (minus sign keys)
3. while 2 soft keys holding reset (reset hole)
4. press Green (call button) when you see instructions on display to do so.
Apr 29, 2010 | HTC P3300 Smartphone
Trying to get local channels through an external antenna I cant get the tv to switch from cable to air. Also, I never programed a parental control password. Is there a factory preset number? I wanted to...
No,must ask Sharp,reset back to factory will not reset password,only setting.Tv should set simple password to easy to remember that the best.Can't switch back to free air,because the password stuck in cable mode.
Jan 10, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hard format of nokia 6030
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard Reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
on/off + * + 3
Before making a Hard reset better backup all your important information: contacts , memo...etc
Dec 24, 2009 | Nokia 6030 Cellular Phone
I cant unkock my phone
hi im rain this code will reset your password nd some settings
--------------------------------------soft reset -------------------------------------
if this fails you can try a hard reset .
---------------------------- Hard reset ---------------------------------------
Nov 15, 2009 | Samsung SGH-F250 Cell Phone
Lands Phones Logo
Top Sharp Lands Phones Experts
Tom Chichester
L Vincent Testa
L Vincent Testa
Are you a Sharp Lands Phone Expert? Answer questions, earn points and help others
