Hello,Beko WM74155LW door will not lock and m/c will not start. I've had it unplugged for 2hrs,what is next step, please.
  • 323 Answers
SOURCE: Refregirator problem
first thing is you need to clean out the fridge and throw away all spoiled food, next you have to defrost the freezer, unplug the unit and let it defrost overnight, place a towel on the bottom of the freezer to soak up the water from defrosting, you can help the defrost process by using a blowdryer
this will speed up the defrost process
good luck
Posted on Jan 16, 2010
  • 1430 Answers
SOURCE: Washer won't start, lights all
The board would be the likely problem if the switch is good. To double check the switch check it for ohms, it should be around 1500 ohms no lower than 1400 if it is the switch is bad if it checks good replace the main control. Here is a link that should help
Posted on Sep 08, 2010
  • 15935 Answers
SOURCE: 417 front loader washer - door doesn't register as
The door lock/latch mechanism has failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
SOURCE: Beko WM74155LW
BEKO WM74155LW Washing Machine - White
Posted on May 19, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a beko wm5120 s which will not start any cycle, i noticed that the door lock in not locking can anybody help , please Regards Graham"
I think a glitch here caused this to be listed in the TV areas and it sounds like a washing machine?
Posted on Dec 14, 2012
BEKO 6108 XE door does not lock and machine won't do anything
might be a knackerd interlock on the door...
Mar 04, 2015 | Beko Washing Machines
Beko washing machine WME8227B. Switch on power, set programme ,press start button, hear the door lock (noticed that the padlock symbol isn't on as nomal) no water flows , checked manual eg child lock, time...
Probably a fault with the lock or latch; should be no problem for an engineer to fix. Just try giving the door a firm push to close it, to see if the padlock light comes on.
Jan 10, 2018 | Beko Washing Machines
Dec 13, 2012 | Beko 142746 TV
Frigidaire Gas Self Cleaning Oven door open in lock position
Hello ericndiana6b - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Nov 27, 2012 | Frigidaire GLGF376DQ Free-Standing Gas...
Beko WM74155LW
Dec 12, 2011 | Washing Machines
Hello my splendide wd2000s wont drain or spin and wont release the door lock...what do you think
If the machine senses that there is water still in the tub, it will not release the door. Unplug the machine you should her a click and the door should release itself. should take about a minute. As far as the drain and spin, remove the washer/dryer back and check the drain pump, check that the lint filter is clean and that the drain hose is clear of foreign objects. I have instructions for how to unlock the door when the machine is in a cycle. If you're door lock is continuously giving problems,i can walk you thru the steps to test it, to see if needs to be replaced. Lets start with those solutions first, if they don't work we can go to the next step, which would be to test the drain pump and the door lock, and also to put the machine in diagnostic mode
Feb 07, 2011 | Splendide 2000S Front Load Washer / Dryer
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
