Hello, my Beko's door will not lock and m/c will not start. I've had it unplugged for over 2 hours, what is the next step please.
  • 193 Answers
SOURCE: Beko WMA765S fills, stops, then drains and stops
i would think about replaceing the timer
Posted on Sep 09, 2009
  • 323 Answers
SOURCE: Refregirator problem
first thing is you need to clean out the fridge and throw away all spoiled food, next you have to defrost the freezer, unplug the unit and let it defrost overnight, place a towel on the bottom of the freezer to soak up the water from defrosting, you can help the defrost process by using a blowdryer
this will speed up the defrost process
good luck
Posted on Jan 16, 2010
marka19
  • 1430 Answers
SOURCE: Washer won't start, lights all
The board would be the likely problem if the switch is good. To double check the switch check it for ohms, it should be around 1500 ohms no lower than 1400 if it is the switch is bad if it checks good replace the main control. Here is a link that should help http://appliancehelponline.com/washercontrolboard.html
Posted on Sep 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: 417 front loader washer - door doesn't register as
The door lock/latch mechanism has failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 10, 2010
  • 6277 Answers
SOURCE: door won't open. wash
(No guarantee but try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Posted on Apr 10, 2011
BEKO 6108 XE door does not lock and machine won't do anything
might be a knackerd interlock on the door...
cheers
Mar 04, 2015 | Beko Washing Machines
I have beko 91442 lx and can get it to start. All lights etc on. Thought it might be child lock but can seem to get it on or off. What can I do please
i think it refers to elec-card
1- first unplug the machine for about 10 min
2- plug the machine and start short program
if led are on please specifies which led are lighting !!
thank you
Nov 21, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Why dosen't Beko WMB 61631s washing machine work?
sounds like a software problem.
Try unplugging for 2 hours, then replugging and starting the cycle.
The long unplug is to drain memory voltage.
Aug 19, 2014 | Beko Washing Machines
Beko washing machine WME8227B. Switch on power, set programme ,press start button, hear the door lock (noticed that the padlock symbol isn't on as nomal) no water flows , checked manual eg child lock, time...
Probably a fault with the lock or latch; should be no problem for an engineer to fix. Just try giving the door a firm push to close it, to see if the padlock light comes on.
Jan 10, 2018 | Beko Washing Machines
My Washer Is Locked!!!!!!
Hello kandlelady_1 - Let's try reprogramming the washer by flipping the household circuit breaker off or unplugging it. It is important to wait roughly ten minutes and then turn the washer back on. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly be experiencing a communication error with the control board, faulty door lock switch or a potential wiring failure.
Jun 30, 2013 | Frigidaire ATF6000ES Front Load Washer
I have a beko wm5120 s which will not start any cycle, i noticed that the door lock in not locking can anybody help , please Regards Graham"
I think a glitch here caused this to be listed in the TV areas and it sounds like a washing machine?
Dec 13, 2012 | Beko 142746 TV
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
The remte control key is not responding with the car
Hi abdumi0f,
Firstly, open your glove box and make sure Valet Mode is not enabled, if it is not, follow these steps.
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Hope this helps,
Lazaruselite
Feb 24, 2009 | 2007 Mercedes-Benz E320 BLUETEC Sedan
Washing Machines Logo
Top Washing Machines Experts
