Question about Ovens Ovens
How to turn on large oven of the built in double ovens Diplomat Elite
SOURCE: the oven turns off after 30 mins
Is the clock re-setting and flashing? Either the fan is failing and the oven is overheating, or the thermostat is faulty and the oven THINKS it is overheating. It is a fail-safe kicking in, momentarily cutting power to the oven to avoid lasting damage.
Set the time on the clock and the oven should be okay to go again, but if problem repeats, replace the fan and/or the thermostat - it is difficult even for an engineer with all his equipment to diagnose which of the two is at fault, but its about all there is to go wrong on a gas oven.
Apparently!
Posted on Jul 20, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a baumatic bc3510ss double oven. everything
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
Posted on Nov 04, 2009
ianem
SOURCE: Top oven and grill of my Diplomat ADP4520 double
there is a problem in the wire connection that can cause a short circuit.
Posted on Nov 11, 2009
heatman101
  • 43501 Answers
SOURCE: Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 18, 2010
  • 11 Answers
SOURCE: Hi I have a Diplomat
If you can hear the oven fan running but the oven is cold is is most likely to be the fan element at fault. If there is no obvious damage to the element it should be checked for continuity with a test meter.
Always isolate the appliance from the mains before investigating
Posted on Jan 22, 2011
My oven wont work
If your gas igniter is bad the gas well not turn on .replace the igniter
Nov 09, 2011 | Ovens
I have a diplomat double oven no instruction or model no the bottom oven will not turn on and i can not get timer to cancel also an a is flashing on top left hand side of clock can you help ?
Sounds like the flashing 'a' means the timer is in automatic mode. I trust that when you turn the bottom oven to on the oven indicator light does not come on. Turn the bottom oven to ON. Then
have a fiddle with the timer. You have to get it to manuel mode. When it goes on to manuel mode the oven indicator light will come on and the oven will then work.
Feb 05, 2011 | Ovens
Hi I have a Diplomat elite single oven (AAA3490). When I put the oven on, it is not warming up. Everything else looks fine. Any advice would be appreciated
Jan 22, 2011 | Ovens
Hi, I have a diplomat double fan assisted oven and the element in the fan oven has gone,the bolts which hold the element in however, have a really shallow head on them and when I try to use a spanner or...
If you cannot remove the screws from inside the oven, then there is really no alternative than to to remove them from the out side of the oven compartment.
If it is built in, this will entail removing irt from the oven hosing, and removing the rear panel of oven, to gain accessw to the element securing screws.
Jan 31, 2010 | Ovens
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to sharemonger@tiscali.co.uk and I will reply with a copy in .pdf file format.
Dec 24, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Andrew Taylor
Andrew Taylor
robert
ray gallant
Are you an Oven Expert? Answer questions, earn points and help others
