Question about Saws
Fixing saw to UP86 - Saws
Gas tank leaks, what to do?
since most of these saws now have poly tanks , the best thing to do is replace them with new one , but on older saws this is not allways possible this is why ive invested in a plastic "welder" from a internet site it's worth it s weight in gold if you can save an old saw from the bone yard by fixing its tank with It
Feb 05, 2016 | Garden
How to fix the choke on homlite 38 cc 16 inch gas chain saw
More than likely, your choke became disconnected. I have attached a link from YouTube of a video on this.
There are many useful video's on fixing chainsaws, from simple fixes such as reattaching a choke lever, to complete tear down and rebuilds.
I hope this helps you get back up and running.
Short video on fixing chain saw choke
Nov 10, 2014 | Garden
Homelite chain saw 3316c
ok check the magneto if rusty clean with fine grit paper then try it if not then may be time to change the coil and magneto..
Jul 13, 2014 | Garden
Motor of the saw runs,but chain does not move.
your clutch is bad and how old is this saw if it is too old it would not be worth fixing
Jul 19, 2011 | Remington 16" Electric Chain Saw
Chain saw I bought last summer. The pull rope to start the saw does not retrack. Took the cover off and loosened the screw and it works, put cover back on and 2 pulls same thing. I've only used it 3...
The fixing post for the pulley has become lower than the pulley for some reason, the fixing screw is now rubbing the pulley instead of bottoming out on the post, quick fix is to find a suitable washer the same diameter as the screw head, fit this between the post and the fixing screw.
Jun 09, 2011 | Husqvarna Garden
Need lower guard kit, seems to be obsolete everywhere.
Go to www.ereplacementparts.com. They have two SHD77M saws listed but both have a lower guard with part number 1619X01182 for $8.42 (+S&H of course) but a saw worth fixing.
Jan 03, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need a replacement motor for a Remington Electric Chain Saw Model 107624-01 EL8. Anyone have any suggestions.
You can buy this complete saw for about 75.00 on amazon. I've heard of others burning up the field and armature in this model saw. You can buy a homelite electric at Home Depot 50-75 depending on model. Doesn't seem like it would be worth fixing, only to have it burn up again. Sounds like it needs a thermal overload to prevent damage. GOOD LUCK1
Jun 30, 2010 | Remington Electric Chain Saw
Saws Logo
27 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
