Question about LG Televison & Video
I have an LG 3D LED TV model number: 55LA9600-TA Serial Number: 308KCAS4E640. The backlight of half the screen keeps shutting off. How can I fix this?
    Top Expert:
  • LG Master
  • 75,581 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on May 19, 2017
dsacco86
  • 1077 Answers
SOURCE: leg mounts for flat screen rca tv cracked at
I found a pair for you. It's on sale now. here's the link:
http://www.shopjimmy.com/catalogsearch/result/?q=L26WD21+stand
One set left. As of June 16, 2009 ( California time 11:00pm )
Posted on Jun 17, 2009
SOURCE: Stolen tv, need serial number
I got an Samsung 52 inch stolen along with 2 others 32 inch television, but I called Conn's and they me the serial number where I purchased the television from. This happened in May, but I still have not recovered my televisions.
Posted on Aug 01, 2010
SOURCE: wurlitzer electric organ model 630 TA serial
Kontakt:morelocksorgan@frontiernet.net they have all parts on stock as well service manuals, this model is very unique it has an value!not a money value, keep it in shape... I owne an 625ta white, it sounds better as the 950 and also better as the 625 spinet model, i don't know why...Jimmy Smith UK recorded an superb Lp"tommorows sound today"
Posted on Oct 01, 2010
Ecollier2012
  • 3459 Answers
SOURCE: My RCA 52 inch projection tv looks 3d. I can't
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
BElectric
  • 1140 Answers
SOURCE: I have LG DVD Player
Hi Chris,
The likely reason is that it's not connected to the TV correctly or the wrong input/source on the TV has been selected. The same audio inputs sockets can often be used for multiple video inputs or you may also have connected the audio cables to an audio input that does not relate to the video input you've used.
There are one or two other possibilites as well, but I really need to know the model number of your TV and the type of cable you are using to connect the DVD to the TV.
Please try all of the inputs on your TV and if you need further assistance, please let me know the model number of the TV and the type of cable you are using. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Mar 26, 2011
My lg TV of three and half years has a black screen with images flashin Intermittently. The sound is fine
What is the model number? If it is only 3 years old, I suspect you have a LCD TV with LED backlight. You quite possibly have a failed LED backlight.
Many LG TVs of this age are starting to fail due to over-worked LEDs in the backlight which create the white light that illuminates the LCD image.
The symptom is TV turns on and off ok, gets sound on the connected video inputs, but has an otherwise black screen with no video on display. You can try to operate the TV near a bright window with lots of sunlight and see if you can perceive a faint image on the screen. A flashlight is often not bright enough to be helpful.
Most of the time, an LED will fail as a short circuit and still allow power to flow through it to other LEDs that will still light up. If one of these LEDs fails as an "open circuit", or if several LEDs have failed in the same circuit, then the power supply detects a fault and shuts the TV down. If the LED is intermittent, you may have flickering. Think of having one light bulb burn out in a string of Christmas lights and having all the lights go out until the bad bulb is replaced... kind of the same thing.
Your TV circuits boards should be fine. In my opinion your TV requires a backlight repair which requires complete disassembly of the entire TV including disassembly of the panel which is a difficult process.
Nov 13, 2017 | LG Televison & Video
My LG tv (Model number: 32LS3410-UB) has sound, but no picture. When I do the flashlight test I can see a very dark image on the screen. Will replacing the LED driver fix this problem?
If you already tested with the flashlight which is the first step in the blank screen with sound fault then you have to test the LED Backlight supply voltages if you are familiar and good in the electronic repair. First you have to check if bulging capacitors for the LED Backlight drive voltage circuit, replace them. If capacitors are good then you have check the backlight LEDs. The flashlight test proves that the power supply is good and TV is working fine because the sound is ok and picture is fine. Attached videos and links may help you for the repair and replacement of backlight LED strips or LEDs itself depending on the type of LED strips used in your model.
https://www.youtube.com/watch?v=Z1DEkSguWtg
https://www.youtube.com/watch?v=YgaL6X6eSaU
https://www.youtube.com/watch?v=EZVQKEp6jxk
https://www.youtube.com/watch?v=T2FboV-1PJg
https://www.youtube.com/watch?v=2pyuXwNkBMA
May 08, 2017 | LG Televison & Video
Black Screen on LG LED TV. From what I can see, I have not backlight, but I have sound and I can see the picture with a flashlight...TV flashes on start up. Is the LED panel or the T-conn board ??.
LED backlight of your TV might gone. If you are a good service technician and know about electronic repair, check LED Driver voltage, if voltages are normal then you can test your LED backlight by applying external voltage to the LED backlight to reconfirm. Link to download Service Manual: https://www.scribd.com/doc/159016486/LGE-47LV4400-Service-Manual-R01-1 LGE 47LV4400 Service Manual R01 1
Mar 31, 2017 | LG Computers & Internet
Can Liquid Crystal screen be replaced for this model?
SORRY but no do not think they can be fixed , just replaced .
Oct 01, 2015 | Panasonic VIERA TX-L47ET5B 47" 3D LED TV...
Screen flickers on and off
If all your other HDMI inputs are out, then I recommend replacing the MAIN PCB
try the following web site: https://www.encompassparts.com/model/ZEN55UB9500UA/_/_/LG/55UB9500UA/55_INCH_UHD_4K_SMART_3D_LED_TV_W_WEBOS
page 4 lists a part number for the MAIN PCB,
HOWEVER, PLEASE MAKE SURE YOU USE YOUR COMPLETE MODEL NUMBER TO ASSURE THE CORRECT PART.
Apr 06, 2015 | LG 55UB9500 55" 4K Ultra HD TV with 2160p,...
Hi I am having problem with my tv bush model s642f while I am switching the tv on the red light keep flashing an it won't come on please help me thanks
It's possible it may be an error code. Depending on the number of blinks it will tell you what to look for when diagnosing the TV.
Feb 13, 2015 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Televison & Video Logo
