Question about Asko Dishwashers
Hi, my Asko keeps draining despite me drying out the bottom. I have checked everywhere and cannot find any blockages. What next?
Rotu
  • 175 Answers
SOURCE: Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Posted on Nov 06, 2007
  • 351 Answers
SOURCE: Asko D3250 Bottom arm not moving
Check that the diverter motor above the wash motor is working and that you havent selected upper basket wash only,could still be a blockage in the lwr arm assy
Posted on Feb 29, 2008
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
SOURCE: Hi, My EdgeStar dishwasher suddenly started
www.edgestar.com/ownersmanuals/DWP40Sownersmanual.pdf - United States
Above is your user manual, below, is the support website for Edgestar.
http://www.edgestar.com/products/dishwasher/dwp40s.asp
Below is a great DIY repair site to assist you in troubleshooting your issue.
http://www.repairclinic.com/Dishwasher-Repair-Help
That's the right thing to do, check, all hoses pimp and fittings for any blockages and check, joins and overfow containers too. To really have a good shot a DIY'ing one really needs a Service manual, sometimes there is a maintenance sheet inside the inspection panel, if one on the unit itself inside, however if not, you need to contact the maker, link provided, and ask them for a service manual. I have checked the 'net, but have been unable to find any.
If you can't track it down, get it looked at by a professional, ask for a "Quote" before allowing any work to commence. Again contact Edgestar and ask them for a referral to an authorised service center.
Posted on Sep 12, 2010
  • 8 Answers
SOURCE: hi, inlet/drain light flushes. checked for
Sometimes the error refers to where the drain pipe connects to the waste under the sink. It gets a build up of gunk over a few years. Just unscrew it and use a chopstick to see if it is blocked. Worked for me
Posted on Dec 23, 2010
Asko D5457 DISHWASHER. Dishes are clean but not dry.. Especially plastics on top eack despite long dry selected. Any ideas as to what may be occurring?
Unfortunately, plastic will not dry well if at all in this model. The only heat for drying is the residual heat left in the dishware after the hot rinse cycle. Plastics do not have enough thermal mass to hold on to the heat long enough to dry. Also, you MUST use a rinse agent in this washer. Those detergent packets with rinse aid in it is not enough. Make sure to keep the rinse aid dispenser full.
Jul 01, 2016 | Asko Dishwashers
Climatronic doesnt extract moisture from the cabin
Does the moisture smell link coolant?
Use a white napkin and wipe the inner windshield,
Compare the color to your coolant tank.
This will verify is this a heater core problem
Next item that can trap water is the A/C drainage problem.
You will need gloves for this.
Most A/C drain is ion the bottom of the center console.
The bottom of the tray is a A/C drain tube and pan.
Check for drain blockage. (DIRTY JOB!)
Jan 16, 2014 | 2002 Volkswagen Passat
Water in the bottom at the end of the cycle
check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
May 31, 2010 | Asko D1706 Built-in Dishwasher
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1805 Frozen
Sounds like the controlunit is bad.
Jan 01, 2008 | Asko 24 in. 1805 Built-in Dishwasher
Asko diswasher
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
