Question about Coffee Grinder Coffee Makers & Espresso Machines
Hi There, I need to purchase descale solvent and coffee grinder cleaning capsules. I live in the Cape Town area and do not know who the agents are. Can you please advise?
2 Suggested Answers
  • 48191 Answers
SOURCE: Please assist with providing agents for maintenance solvents and capsules for my Saeco Talea Ring coffee machine. I live in the Cape Town area.
you will get thatb infomation from the manufacturers web site
fixya site is not an agent directory
Posted on May 19, 2017
Why won't my Saeco Odea Giro descale?
Might need some urn cleaner to do a proper job. Scale is dry chemicals that you want remove so use the proper cleaning agent.
Aug 09, 2014 | Saeco Odea Giro Espresso Maker -...
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Flashing dregdrawer and descaling lights
You need to run the descale process, which essentially cleans the plumbing.
Aug 19, 2012 | Saeco Odea Giro Plus Coffee Maker
No coffee comes out, only water despite capsule inserted. Capsule doesn't pierce at the front.
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
May 28, 2011 | Nespresso Citiz D110
Ran descale program and coffee still tastes funny (bitter)
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
Apr 05, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
How do I properly clean the coffee maker and then get the light to go off?
  1. Allow the unit to cool completely and unplug it before cleaning. use a sponge dampened with soapy water to clean the outside of the coffeemaker, then dry carefully.
  2. Open the reservoir cover and the filter compartment. Remove the coffee grinder lid, the grinder, the filter basket, its cover and the support.
  3. Wash the pieces along with the measure, the carafe and its lid in warm, soapy water, rinse thoroghly and dry. Then replace them in the unit.
  4. All these pieces are also dishwasher safe.
  5. Never pour water inte the unit when the grinder is not in place.
  6. Wipe the part under the filter basket and the heater plate with a damp cloth.
  7. Do not wipe the inside of the reservoir as this may leave fabric or paper residue.
  8. Do not use abrasive sponges or cleaning agents as these could damage the finish.
The reservoir cover may also be removed to facilitate cleaning.
Over time and through normal use, lime deposits will build up.
Scale can interfere with the fine mechanics and give the coffee a harsh, bitter taste. For reason, your coffeemaker should be descaled regularly to guarantee good coffee. The frequency of descaling depends on how hard the water is and how frequently you use the coffeemaker.
  • To descale, dilute 30cl white vinegar in 30cl water, pour the mixture into the reservoir and begin a brew cycle.
  • Then run two full cycles by filling the reservoir with water (but no coffee) to rinse the system.
Hope this will help you.
Aug 27, 2008 | Cuisinart Coffeemakers
What is the best method to clean the Cuisinart Grind and Brew coffee maker? And how often?
Get descaling solution at any drug store and follow the manual on the bottle. When you do this once a month that should keep your machine in top form
Aug 17, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Saeco coffee machine
I think your grinder engine has broken and have to be replaced.
Oct 05, 2007 | Saeco Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Coffee Grinder Coffee Makers & Espresso Machines Experts
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a Coffee Grinder Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
