Question about Lands Phones
My phone rings for 9 seconds when incoming calls are coming in... then it cuts the caller off itself, how do I change the settings so that the phone rings longer
  • 2961 Answers
SOURCE: Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Posted on Aug 07, 2007
  • 201 Answers
SOURCE: We cannot hear a ring on incoming calls
Sounds like your system defaulted. Only a few phones ring at system default and you may not have those ports connected. First, you need to figure out which Comdial Impact system you have. The phone will work on a few different Comdial systems. Find the main box and get a model number from that. You'll have to tackle re-programming ringing yourself or pay a local company to do it. If you do it yourself you will need the "programming and installation" manual specific for your system. A "user guide" will be of no use to you. You can search the net for "Comdial Digitech, Impact & Impression Programming & Installation Manual" Next, I would suggest a UPS backup for your system so this does not happen again. Unless you have a large carded system with dozens of phones, your phones require less power than a typical computer so a UPS made for a computer will be fine. The system will default either when the system memory battery goes too low or I have seen a few cases where power fluctuations will cause it (like when the power goes on-off-on-off rapidly in a storm) either way a UPS system with surge protection will help.
Posted on Aug 30, 2007
  • 52 Answers
SOURCE: my phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Posted on Jul 17, 2008
SOURCE: can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Posted on Mar 03, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
Oct 28, 2014 | Panasonic KX-T7730 Corded Phone
Nokia 6085 drops incoming calls
in profile management under caller settings you should find an option there to set the number of rings before timing out. Set it to whatever your preference is and it should solve your problem. otherwise it may be a provider issue, try calling AT&T and explaining what's going on.
Dec 02, 2013 | Nokia Cell Phones
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
Unknown callers wont ring
maybe check on the ringer type for restricted numbers- you can change ringers by all calls, restricted calls, and caller id numbers. your incoming restricted numbers is probably set at none or silent
Apr 20, 2009 | Motorola Mobility Moto Q
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
Samsung g600 - receiving a call
Click Menu > # Settings
1 Phone settings
On this you can change the setting on what to be displayed when you receive a call.
Phone settings
→ Show caller
Set the phone to display or
block caller information on
all missed calls and
incoming messages
Let me know if you need more info
Jan 01, 2008 | Nokia 1600 Cellular Phone
Phone wont play ringtone with incoming call eventhough one is selected will spell out number calli
with the phone closed, goto tools, voice on settings in the lower right.......scroll down to call alert.......change to ring only or caller id+ring....on the env that should solve your problem
Dec 12, 2007 | LG enV VX9900 Cellular Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
