Question about PANDIGITAL Computers & Internet
Pandigital 8" digital photo frame has stopped working,
After connecting power supply and switiching on there is no light on the screen,
SOURCE: my pandigital 1.8 inch digital photo frame won't turn on
You have to leave it in your US-B overnight to charge.
There is nothing in the instructions to explain this.
Posted on Jan 06, 2009
jyackle5
  • 8197 Answers
SOURCE: I NEED THE PAPERWORK AND USERS MANUEL FOR 8" DIGITAL PHOTO FRAME
Here you go. click on the link below for the manual
http://www.westinghousedigital.com/pdf/208_User_Manual.pdf
Good Luck and Please Rate FixYa!
Posted on Jan 20, 2009
robmcd27
  • 423 Answers
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
SOURCE: Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Posted on Dec 28, 2009
noname2
  • 109 Answers
SOURCE: My pandigital photo frame doesn't work at all.
This frame cannot initialize; this is an internal memory issue. Connect the frame to your computer with the USB cable and to the AC outlet. Now turn it on. Under Computer or My Computer, look for a Pandigital (X:) drive.
If you see that drive, right click on it and select Format.
Choose FAT or FAT32 as the file system, check Quick Format, then Start.
Once it finishes, unhook the frame and restart it.
If you do not see that drive, your frame is toast. Grab your receipt and return to the store or call the company.
Posted on Jan 23, 2010
Tip
Pandigital digital Picture frame PC Recognizing Tip
Hi I just got this frame for Xmas ,,, I tried it my 1st Time it worked perfectly ... I then had other pics I wanted to have on my new frame ,,, Unfortunately I had no success getting the pc to recognize the frame ,, after a quick internet search I found out that I wasn't the only one this was happening to ...
Long story short ,, I figured it out ,, just make sure the power supply is plugged in when you are connecting the frame to a pc via usb ..
Thanks hope this helped .
BORNINDAFIRE
on Dec 28, 2008 | PANDIGITAL 7" Digital Photo Frame With...
How do I get"connected to computer "off screen on my 8" Aluratek digital frame?
pluging in a usb cable from a computer that allready has the device driver loaded , should send the photo frame into accept mode automaticly , then its all done via the connected computer , nothing on photo screen should matter , till usb cable is disconnected , sorry you cant leave cable connected .
Dec 31, 2014 | PANDIGITAL 8.0" Digital Photo Frame...
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
I want a Internet-connected photo frame, but I dont have a Wi-Fi network. Is there any solution for this?
You can get the Pandigital 8-Inch Photo Mail Digital Photo Frame. It connects to the AT&T's cellular network. It's a really great solution. You can find it on amazon.
Feb 11, 2013 | Photography
I lost the plugin cord to my ditigal picture frame. Can I get a replacement? R. Raver
It's a 9 volt, 2 amp power supply.
Here's one for sale on eBay:
http://cgi.ebay.com/AC-power-adapter-Pandigital-PAN70-0-Digital-frame-/320396099001#vi-desc
Here is Pandigital's toll-free customer number:
1-800-715-5354
Jan 07, 2011 | PANDIGITAL 7" Digital Photo Frame With...
My Pandigital frame was working fine for a couple of years and now the screen is totally black.
that is probably the back light system neon where they defective
or the power supply its self
it is probly an easy problem to fix by a good technician...
good luck
regards allan.
Sep 01, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
Where to get power supply?
http://www.shopping.com/xPC-GeCube-Pandigital-8-Inch-Digital-Photo-Frame-with-2-Interchangeable-Frames
Mar 09, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
My pandigital frame no longer displays anything. You plug it in and it's a blank screen
If you have an all grey screen than the frame is dead --- which menas throw it away. Check voltage on the power supply. Make sure voltage matches the output on the power supply. Also try connecting it tto the computer and formatting the internal memory.
Dec 02, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Computers & Internet Logo
15 people viewed this question
Top PANDIGITAL Computers & Internet Experts
Stojan Nikolovski
Stojan Nikolovski
Danny Kuhlmann
Are you a PANDIGITAL Computer and Internet Expert? Answer questions, earn points and help others
