Question about Welding Tools
Wire feed not smooth in boc 150c mig need to access manual.for this model can you help
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
CarlGehrke
  • 169 Answers
SOURCE: have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Posted on Mar 01, 2009
  • 9 Answers
SOURCE: Wire does not feed on MIG welder
my lincoln mig welder did the same exact thing!! I thought what you did, drive motor bad. But it wasn't, on mine there is a reset/breaker button, it's like a 25 amp fuse that can be reset, it was bad! so I took the 2 wires that went in and out of it and jumped them together (not advised) to see if it would work then. BINGO!! now I have to find replacement. Look inside for a fuse or some thing like that.
hope this helps, oh yeah, when I ask the mechanic at the welding store he said that drive motors rarely go bad!!
Hawk
Posted on Apr 10, 2009
  • 5 Answers
SOURCE: owners manual for a century wire feed 83160 mig
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Posted on Apr 30, 2009
My wire feed wont work properly its brand new never been used
I am guessing you are as new to the welder as it is to you. I suggest you read the manual carefully and ensure the machine settings (torch tip and drive roller size/pressure) are correct for the wire and type of wire you are using. Ensure also the wire is clean and corrosion free.
Test the wire feed without wire initially, ensuring the wire feed roller turns and the speed varies smoothly as the wire speed control is varied. If there is doubt about this the machine should be returned to the supplier for repair or replacement.
If you are unfamiliar you won't do better than go somewhere that regularly uses a mig welder and ask to observe for a while - your local vehicle workshop perhaps.
Aug 14, 2016 | Welding Tools
My C/H Mig. Mo. WG3000 Wire feed will not spool out smoothly, wire jerks when welding is it a Speed control or Drive deck Please help
As long as the motor keeps turning fluidly, then the fault lies in something blocking the wire. I'd replace all the consumables in the torch (tip, tip adapter, nozzle) and most importantly the liner as it may have become clogged. Also check the rollers for a build up of metal, running them under a wire brush cleans them up well. An other reason could be simply that your wire on its roll has become tangled and is not rolling of its reel nicely.
Jun 15, 2011 | Campbell Hausfeld ® 115V MIG Flux Core...
Need an operating manual for the century 80
Do a web search for lincolnelectric.com and look for the manual for this model.
Oct 12, 2009 | Lincoln Electric LE 83180 Century...
Wire feed does not stop. Not the trigger.
Ck the feed roller contact relay
Jun 02, 2009 | Welding Tools
Handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Apr 06, 2009 | Hobart Welders 500505 Handler 140 MIG &...
I have access to a century mig model 117-3-, 90 amp, 120 volt. the wire feed works and it welds, but it isn't getting 12 volt power to the feed. it might be the circuit board. i know the feed works...
yes its fixable,check the main contactor for proper voltage first,power boards are high dollar,so check the price of new one then decide if you want to put that type of money in the unit.
Feb 01, 2009 | Lincoln Electric LE 83180 Century...
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Mig welder tripping power supply
the breaker could be bad. try to change the breaker
Dec 09, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Electrical problem with mig welder
Carl
Nov 19, 2008 | Welding Tools
Welding Tools Logo
171 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
