Question about Platinum Computers & Internet
My GB platinum will not shut down - Platinum Computers & Internet
How to upgrade new songs to my Platinum BMB-ONE HDD/DVD player
How to update songs (Hard Disk Model):
Method 1 - Single Volume Update Only
This method will require a Flash Drive.
Song Update data and Certification Key data will be written in the Flash Drive.
You can bring home the Flash Drive and be able to update the Platinum karaoke player by your own easily.
a. Bring a working Flash Drive to a Platinum Karaoke branch near to you and surrender it to our sales representative. Be sure to get a receipt. Your flash drive free space should be atleast 1 GB.
b. Our sales representative will then send your USB Flash Drive to our Head Office for processing
c. The process will take about 5-7 working days
d. Once you get your Flash Drive, ask for instruction on how to use the Updater
Method 2 - Multiple Volume Update
This method will require a USB Flash Drive and Hard Disk Drive in your Platinum Karaoke player.
Hard Drive will be re-formatted and be written with Fresh Updated data.
Certification Key will be written in the USB Flash Drive.
You bring home the Hard Disk Drive and Flash Drive, re-install the Hard Disk Drive in your Platinum Karaoke unit, and insert the Flash Drive to run Certification process.
a. Carefully disassemble Hard Disk Drive from the Platinum karaoke unit.
b. Bring the Hard Disk Drive and 1 USB Flash Drive (at least 1 GB of free space) to our sales representative nearest you (See List of Branches here)
c. Our sales representative will then send your Hard Disk Drive and Flash Drive to our Head Office for processing
d. The process will take about 5-7 working days
e. Once you get your Hard Disk Drive and Flash Drive, ask for instruction on how to finalize the Update process
How to Install the Update:
a. Make sure that the unit is switched off.
b. Attach the Flash Drive/Hard Disk/SD Card into the unit. For X2 model please note that MicroSD is not applicable for update.
c. Switch the unit ON.
d. Update will automatically run. Wait for the unit to automatically shut down.
e. Remove the Flash Drive/Hard Disk/SD Card. Switch the unit ON.
f. Update is Complete.
How to update songs (DVD Model):
a. Directly purchase DVD (comes with additional song list) from a Platinum Karaoke branch near you.
b. Play the DVD and enjoy your newly updated songs!
Nov 09, 2010 | CP Technologies USB HDD Platinum Series...
My keurig platinum keeps shutting down by itself. This is the 3rd one????
Contact Keurig service via their web site (give them your machine's serial number). I did (had my unit for 2 months).
The response (1.5 days later) was an email informing me that a new unit is on its way. They didn't even want the old one back (which tells me they probably recognize the problem and do not need to inspect the old unit).
I got NO hassles from them. I have NO complaints on how they are handling the problem (other than the annoyance of having the machine shut off on me for no obvious reason).
Otherwise, I love the machine (and their service responsiveness)
-David
Jan 07, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum shuts off after one brew. Will
I came up with a very simple workaround to fix this issue:
http://www.nate-lewis.com/blog/?p=288
The problem is with the water tank not having a proper seal to the brewing unit.
Dec 28, 2009 | Keurig Platinum B70 Coffee Maker
Everytime I click on the clip art it shuts the program down and sometimes it shuts down my entire computer. Any ideas???
u need to run the windows on safe mode then uninstall this program cause it's really stops ur computer when u run it
Jul 08, 2009 | Broderbund American Greetings Creatacard...
Pokemon platinum restarts with action replay have removed some cheats, still nothing
Yep. One or more of the Action Replay cheats you have enabled is making it shut down. Just edit/fix them or disable them.
May 13, 2009 | Nintendo DS Console
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Computers & Internet Logo
Top Platinum Computers & Internet Experts
john h
MarcellusA
Level 1 Expert
Tom Chichester
Are you a Platinum Computer and Internet Expert? Answer questions, earn points and help others
