HOW MUCH I WILL GET IF I HAVE WON TWO NUMBER ON ONE LINE
Dishlex dishwasher won't complete a cycle. Number 60 shows up and a small flashing line. ??????
Drain pump is blocked. .If you are good with tools you can clean it yourself. Let me know
Mar 28, 2013 | Dishwashers
Why won't my U-line refrigerator turn on at all?
What is the model number of your unit?
Nov 11, 2012 | U-Line Refrigerators
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Sep 28, 2012 | Washing Machines
My line won't rewind on my Shakespeare Encore reel. After casting, the bail snaps in place, but when I reel in, the line won't reel in. The spool turns with the bail, but doesn't retriev
Your line is on the wrong side of the bail. Rethread the line so its over the bail so that after the cast you flip it up it catches the line and retracts it.
May 05, 2012 | Sport & Outdoor - Others
Won't stay running
in can be a number of things to check main thing is piston and rings , crack in the fuel line , ignition coil , or check valve in carby , air leak in crank seals
Aug 16, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bibbliography of real numbers
Real Numbers are just numbers like: 1 12.38 -0.8625 3/4 ?2 1998 In fact:
Nearly any number you can think of is a Real Number
Real Numbers include: yes.gif Whole Numbers (like 1,2,3,4, etc) yes.gif Rational Numbers (like 3/4, 0.125, 0.333..., 1.1, etc ) yes.gif Irrational Numbers (like ?, ?3, etc )
Real Numbers can also be positive, negative or zero.
So ... what is NOT a Real Number? no.gif ?-1 (the square root of minus 1) is not a Real Number, it is an Imaginary Number no.gif Infinity is not a Real Number And there are also some special numbers that mathematicians play with that are not Real Numbers
Why are they called "Real" Numbers?
Because they are not Imaginary Numbers.
The Real Numbers did not have a name before Imaginary Numbers were thought of. They got called "Real" because they were not Imaginary. That is the actual answer!
The Real Number Line The Real Number Line is like an actual geometric line.
A point is chosen on the line to be the "origin", points to the right will be positive, and points to the left will be negative.
real-number-line.gif A distance is chosen to be "1", and the whole numbers can then be marked off: {1,2,3,...), and also in the negative direction: {-1,-2,-3, ...}
Any point on the line is a Real Number:
  • The numbers could be rational (like 20/9)
  • or irrational (like ?)
But you won't find Infinity, or an Imaginary Number.
Real does not mean they are in the real world blue-speech.gif They are not called "Real" because they show the value of something real.
In mathematics we like our numbers pure, if we write 0.5 we mean exactly half, but in the real world half may not be exact (try cutting an apple exactly in half).
Jul 10, 2011 | Computers & Internet
My 50 inch hitachi hd projection tv picture won't
This T.V. more than likely has a bad lamp. I don't know the model number so look up on ebay for a lamp replacement by model number after you inspect it and find it to look cloudy or exploded.
Jun 20, 2011 | Hitachi Televison & Video
I have Lexmark X125 and get message "Check Cartride" I put a new Black Cartride in and get message " None Changed" Printer won't print. What can I do?
What is the black cartridge version that you are using on your Lexmark X125 printer? If you are inserting a photo cartridge on your printer, please follow these steps: 1. Remove the black cartridge and insert the photo cartridge. The printer LCD screen will display CARTRIDGE? NONE CHANGED. 2. Press the Options button to select NEW RIGHT and then press Start. The printer LCD screen will now display RIGHT CARTRIDGE? 3. Use the Options button to select the STD PHOTO cartridge type and click Start. An Alignment page will then print. When the Alignment page is fully printed, the LCD screen will display CARTRIDGE ALIGN. 15 [00-30] A , where - 15 represents the straightest line on the page; - [00-30] is the value range you can select from, between 00 and 30 - A represents the line in each section. 4. Use the numbers on the keypad to select the number of the line you think is the straightest. As you press the number, the LCD will change to the next line automatically. Select the number representing the straightest line in each section.
Source: How to Install the Photo Cartridge in Standalone Mode
May 10, 2011 | Lexmark X125 All-In-One InkJet Printer
I won this camera on line at an auction and would like to find the upload sofware on t his site for free!?
Since you didn't tell us the model number, you'll have to do this yoursef.
Go to http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
select Digital Cameras from the drop-down list. When the next drop-down list shows up, select the camera series. Select the model number from the third box, then click Go.
Sep 28, 2010 | Kodak Cameras
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
