Question about Lands Phones
Turn off visual ringer - Lands Phones
2 Suggested Answers
  • 1196 Answers
SOURCE: The visual ringer switch on
I will suggest you reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem. If that did not fix the problem, let me know.
Posted on Mar 10, 2011
How do I turn off the visual ringer red light which continues to flash on the handset even though there are no messages on there?
this is the procedure for uniden dect 6.0
press menu
scroll to-- answering set up and keep going till you get global set up
press menu
scroll until you get VMWI
press menu
scroll until you get--- yes
press menu
press end
keep this as it happens a lot when NBN is in the system
Jan 28, 2018 | Lands Phones
How to stop the visual ringer blinking
That might be the Voice Mail Warning Indicator.
On the D1680 and similar handsets, it is reset by:
1. press [menu]
2. scroll down to "Global Setup", press [select]
3. scroll down to "VMWI Reset", press [select]
4. scroll down from "No" to "Yes", press [select]
5. handset will chirp, blinking lamp goes out,
6. press [END]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Mar 09, 2016 | Uniden Lands Phones
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
Do not know how to turn off the slient mode
You can silence the ringers on the base and handsets at the same time. It doesn't affect the visual ringer on the phone in standby, press and hold Silent on the base. The phone automatically turns on the answering system and shows Do Not Disturb in the display on handset. (The answering system answers any incoming calls without playing anything through the speaker.)To cancel, press Silent again. If you turn the answering system off while Silent Mode is on, the phone turns off Silent Mode.
Nov 29, 2013 | Uniden Lands Phones
How do I shut off the blinking light on the handset to my cordless phone. I have tried everything. I believe its called a visual ringer. Blinks all night
Is the visual ringer or the message light? If it's the message light then you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 13, 2011 | Uniden Cordless Phone
The visual ringer keeps flashing on my uniden cordless phone
I CALLED UNIDEN WITH THE SAME PROBLEM.
THE VISUAL RINGER IS FLASHING WHEN YOU HAVE OLD EMAILS. YOU HAVE TO DELETE THE OLD EMAILS
Feb 10, 2010 | Uniden Cordless Phone
Continuous Flash of Visual Ringer(Uniden DECT 6.0 Cordless)
UNIDEN MODEL EZX290 HANDSET>>>VISUAL RINGET AT TOP (YELLOW LED) FLASHES. HOW DO I TURN THT OFF?
Jun 28, 2009 | Uniden DECT 6.0 Cordless Phone ID
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Lands Phones Logo
29 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
