Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cadet does not fire
1210 cub cadet does not fire ,where is the points box
  • 202 Answers
Is it the 12 hp kohler? if so it is electronic type no points.
have you tried cleaning the flywheel magnet and coil?
use very fine sandpaper and clean them. if still no go gheck kill switch and nothing there is is probally a bad coil.
Posted on Jul 25, 2009
2010 cub cadet volunteer,was running,wife shut it off,and would not restart,all dash lights work,tilt box ,lights,all work..help!
i would check the ignition coil could be the ground wire is not releasng from the brake take te ground wire off and see if it fires.
Sep 20, 2017 | Cub Cadet Garden
Parts for Kohler Model# 13WVA1C5009; Serial# 1K105H20218
Hello Marty Wells,
Your Kohler unit resolves to a CUB CADET XT1-LT42
(see below)
Cub Cadet XT1 LT42 13WVA1CS010 13WVA1CS009 Cub Cadet XT1 Enduro Series...
Manual
Cub Cadet XT2 Enduro Operator Manual Page 36
Still not finding CARBURATOR parts...
I have had phenomenal success finding
parts for MUCH older units on eBay
(but it really helps to know what the carb looks like)...
ELSE...
In the U.S.A.
Yellow Pages, or contact Cub Cadet LLC at P.O. Box 361131,
Cleveland, Ohio 44136-0019, call 1-877-282- 8684 or
Log on to our website
at www.cubcadet.com.
In Canada:
Contact MTD Products Limited, Kitchener, ON N2G 4J1,
call 1-800-668- 1238 or log on to our website at www.mtdcanada.com
Hope this helps
Carnac the Magnificent
Aug 27, 2017 | Garden
1250 cub cadet will not fire. Put in new point s, condenser, plugs and coil. Still no fire.
Hi have u tried cleaning the carby & the jets in it .U mention it won't (FIRE) do u mean it.wont start or do u mean there is no spark. . Cheers.
Dec 29, 2016 | Cub Cadet Garden
I HAVE A CUB CADET 173CCOHV SELF PROPELEDWON'T START NEW PLUG GASTO THE CARB AIR FILTER OK STILL WON'T START
I would check to ensure the coil is firing. You can do that with a plug tester attached between the plug wire and the plug and check to see if there is fire to the plug or remove the plug and ground it to the motor and see if it fires as the engine is rolled over. Hope this helps.
Oct 24, 2016 | Cub Cadet Garden
Adjust idle speed
on the top of the carburator there should be an adjustment to set the idle speed
Apr 25, 2013 | Cub Cadet Garden
I have a Cub Cadet LT 1018 with an 18hp Kohler motor. It was running fine today while cutting the grass it just shut off. It will not restart. The engine will crank over fine but it will not fire. I...
First make sure you have oil in it. Next take off the air cleaner box. Try restarting it if it runs fine clear or replace the air filter. Also check to see if it’s getting spark.
Dec 22, 2017 | Cub Cadet Street Sign- tractor lawn riding...
Problem with left side hydrostatic transmission
This is a well documented problem with cub cadet ZT transmissions. They tend to go bad after 200 hours of use. Sometimes having the dealer change the transmission oil will help (they need to remove the transmissions to do this!). Most times, the transmission is gone & must be replaced ($800-$900).
Sound to me like a design defect. My ZT-50 lasted only 4 years. Needless to say, the replacement was not a cub cadet.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
283 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
