Question about Ovens
Oven is not hot properlly - Ovens
Amica oven door gets so hot that my child has burnt hes hands and needed medical attention
Amica is a European brand, I recommend you contact the company headquarters or a competant local repair shop. Any oven left at a very high temperature for a long period of time gets pretty hot, though, and an eleven month old baby has pretty tender skin.
Jul 19, 2014 | Ovens
The oven isnwt work.
Hello,.
Please check on the power connection from the wall connected to the oven if it properlly connected to the oven , note if the connection is in it best position then you will have to to do some practical work to sole the problem your self .
From the above instruction you will have to get your self the basic tools to open up the oven from the screws carefully.first of all put off the power supply connected to the oven from the main power supply or wall ,unscrew the screws on the oven with tools (screw driver)then trace the power supply wire down to the panel of the oven to locate were the problem is from.
and also the fuse of the oven can also the cost of the problem it is located at the back of the oven very closet o the panel closer to the heater which might need replacement
Thanks
Sep 03, 2011 | Ovens
My bosch oven grill element is not working and my oven does not seem to be getting as hot as it should. any ideas what it could be.
More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Bosch HBN 430560B / 430520B Single Oven
Oven getting warm but not hot?
If it is an electric fan assisted oven, and the fan is working o/k, \then you need to fit a new oven element., usually located at rear of oven compartment.
Thanks.
Nov 16, 2009 | Smeg Ovens
The sides and front of my oven get extremely hot, why? I am afraid to use the oven in fear it will burn the cabinets next to it. The oven is not self cleaning, is this why it is getting hot? My last oven...
Normally oven gets hot but just lukewarm externally(front and sides). Compare it when it
was still new. If it is hotter than it was, then the insulation inside have deteriorated thru time. Have it check for possible insulation replacement Hope this will solve your problem. Don't forget to vote for me. Thanks.
Sep 22, 2009 | Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Exterior surface of oven gets hot when turned off
What do you mean by very hot? Is it too hot to touch? Hot enough to sizzle when a drop of water is put on it?
Oct 06, 2007 | Dacor MCS130 Millennia Electric Single...
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
