No hot properlly less hot - Computers & Internet
1997 mercury villager, when it gets warm near operating temp it starts MISSING, LOSING POWER AND STALLING. DOESN'T RUN WELL AGAIN TILL TOTTALY COOLED OFF. DOESN'T OVERHEAT
Could be any number of thing's on the vehicle . When it won't start you need to see what's missing Spark or fuel pressure . Then diagnose the system not function properlly . Lets say the ignition system is the problem , no spark . Could be a bad coil breaking down when it get's hot , or crankshaft position sensor or any sensor for that matter . There are good videos on youtube on finding which system is not working .
No Start Diagnostic Basics EricTheCarGuy
Apr 03, 2017 | Mercury Cars & Trucks
Runs rough and dies what 1 hour well star for 30 min. then die
Check your fuel system, especially your fuel filter and fuel pressure regulator.
Jul 20, 2014 | 1994 Ford Probe
Honda accord
Do any of the other Heater functions Work (Properlly) Or only the deffrost Mode. If none of the ohter haeting functions) are working (Properlly)Being the age of the car,If the (Thermostat) Was never changed (Replace) it. If it still is over heating you could have a (Cracked) Head gasket. Go the cheapest route first, End replace the (Thermostat,End see what happens.How many KM is on the car? If it has high milleledge .(Deffently) Change the (Thermostat) Hope this works for you.
Oct 05, 2012 | 2003 Honda Accord
It doesnt cool or freeze
is compressor running or has it overheated unplugg let sit a few hours if hot /if running is suction line cold disch/hot if not may want to check charge these units require exact amount of gas to work properlly .
if all conditions stated are ok cap tube/ compressor may be cause always consider age of unit ref. units are relitivy cheap now may be cheaper to replace esp if 10+ years old new units are so much more efficent
Jan 18, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
When you do a hard reset and go to secure erase it does not do anything
You need to have the 2.0 update installed before the secure erase will work properlly. You can download this from the Palmone website. It updates the hidden directory and changes some of the palm os so that it will now do a reset and restore properlly.
Thats the only thing that I can think of that fits your description.
Jun 19, 2009 | Palm LifeDrive Handheld
Servo doesn't move properlly
Ok it was the potentioameter. There is a metal pin going in it. If they et detached that happends. Glue them and it flys again! Good luck!
Jun 01, 2009 | Spinmaster Air Hogs CHLD Twin Thunder
O2 xda iis
Sorry yur power ic is damaged just replace this ic yur phone will work properlly...
Aug 13, 2008 | O2 Xda IIs Pocket PC
there may be three points 1 may be ram (memory) 2dry point in main bord 3 fan is not working properlly.
Oct 02, 2007 | Computers & Internet
Recording and PA system
Install properlly that software (Driver).
Sep 15, 2007 | Computers & Internet
Make sure the ink is properlly installed.
Aug 24, 2007 | Brother MFC 7150C All-In-One InkJet...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
