Switching from meters to yards - Office Equipment & Supplies
How do I switch from meters to yards
1 meter equals 1.093
so just multiply meters or divide yards.
Jan 31, 2015 | Miscellaneous
V3 change meters to yards
MODE and UNIT OF MEASURE OPTIONS
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower
right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will
begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature,
see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to
select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the
M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite
will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Aug 03, 2014 | Bushnell Tour v3 Rangefinder With Slope
What is the difference of a yard and a meter
A meter is about 39.37 inches, so the difference between a meter and a yard is about 3.37 inches.
Alternatively, a yard is exactly 0.9144 meters, so the difference between a meter and a yard is exactly 0.0856 meters.
Jul 05, 2014 | Computers & Internet
V3 not jolting
The TOUR V3 can be used to measure distances in yards or meters. The unit of measure indicators are located in the lower right portion of the LCD. To select between yards and meters, press and hold the POWER/FIRE button. The display will begin to cycle through the setup options: Yards w/JOLT, Yards, Meters w/JOLT, Meters (for details on the JOLT feature, see "About JOLT"). When the units and JOLT mode you want to use are displayed, release the POWER/FIRE button to select it. If you are changing from yards to meters, a change in unit of measure will be indicated by the illumination of the M for meter indicator while the Y for Yard indicator is turned off. If you are changing from meters to yards, the opposite will occur. The TOUR V3 will return to the last unit of measure setting used each time the unit is turned on.
Feb 12, 2014 | Optics
I would like to convert yards to metres example 2390yards how many metres and 144 yards how many metres
  • 1 Understand the formula. Converting units of measurements always requires a specific formula. The procedure from yards to meters is X (yards) multiplied by "0.9144" meters.
  • 2 Write your formula with the number of yards. Multiply by "0.9144." For example, 100 yards * 0.9144 =?.
  • 3 Use a calculator. In the example above, 100 yards * 0.9144 =?, the answer is 91.44 meters.
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 04, 2011 | American Standard Water Heaters
8.1 meters to yards
1 meter = 1.0936133 yards so 8.1 meters = 8.86 yards or 8 yards, 2ft, and 7in
Mar 15, 2011 | Office Equipment & Supplies
How many meters in a yard
There are 0.9144 meters in a yard
To convert from yards to meters, multiply by 0.9144. To convert from meters to yards, divide by 0.9144
Mar 08, 2011 | Office Equipment & Supplies
Recently purchased ypc 600, no manual, on screen read-out is in meters. can I switch this to yards?
Two buttons on the top. The big one is the power/fire button, the smaller one is the mode button. Hold down the mode button for at least 5-6 seconds and it should switch to yards instead of meters. (Y to M)
Good Luck!!!
MTG
Jun 20, 2009 | Bushnell Yardage Pro 600 Rangefinder
Acurate distance measuring
hold down the mode button for at least 5 seconds and it will change from meters to yards....or vice versa
Sep 17, 2008 | Bushnell Tour V2 Pinseeker Laser...
Changing Modes
press the power button to turn the unit on then, while looking through the monocular, press and hold the mode button for 5 seconds. You will see the unit of measure indicator switch from meters to yards. Good Luck!
Apr 14, 2007 | Bushnell Yardage Pro 800 Compact...
18 people viewed this question
jasbo
jasbo
