Question about Westinghouse DPF-1021 Digital Picture Frame, Digital Photo Viewer
How to repair a digital picture frame
How to repair a digital picture fram.It worked for a while and the next time I turned it on nothing happen. the red light on the side, tells me it is on, but the frame itself remains dark
My photo frame comes on but the blue light on the side flashes when it stops it says Please wait on the frame and doesn't come of that :(
Anybody know how to fix it??
Thanks
Posted on May 04, 2010
  • jkoliwia Jan 30, 2011
    Wrrrrrrrrrrr! WHo can help! who can answer those questions!!!!!!!!!!!!!!!!!!!!! I have the same problem and WHAT TO DO !!!!!!!!!!!!!!!!!!!!! Just DO NOT BUY ANYMORE DIGITAL PICTURE FRAME - it is garbage !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Westinghouse dpf 0703 which is brand new has lines through the screen. It did this at first but then it worked while we downloaded pics however it blanked again a little later. I am freaking out.
Posted on Jan 16, 2010
How do i down load my photo's from my coumpter to the fram
Your photo frame must have come with a USB cable. Plug the larger end of that cable into a USB port on your computer and the other end into the photo frame. Turn on the photo frame (your computer should already be on). A dialogue box will pop up. Select to continue. Open up Windows Explorer. Your photo frame will show up as a "Removable Disk". Still in the Windows Explorer, go to the directory on your computer where you have the pictures you want to transfer. Select the pictures, right click on them and select 'Copy' from the menu that pops up. Go back to the photo frame (the Removable Disk), right click on it and select 'Paste' from the menu.
Dec 12, 2014 | Audio Players & Recorders
Picture frame won't turn on
I would think sometimes it requires time to Charge the Battery before happy face on screen comes on...loL :). Try to plug in adapter cable, or power cable, and leave it plugged in for a bit. Then try again later :)
Apr 03, 2010 | PANDIGITAL 6.0-Inch Digital Picture Frame...
My didgital frame will not turn on. ADS-18H-4 0918G
My didgital fram will not turn on. ADS-18H-4 0918G switching adapter does have a slowly pulsing green light. But will not turn on the picture frame. Where can I get a replacement or how do i get it to work
Mar 22, 2010 | SmartParts SP15MW (092566981886) Digital...
Transfer pictures
Dear remove the write protection on your disk to eliminate this message, you computer or fram memory is write protected. check the properties of those and remove if they are write protected. this is resolve your issue.
Good luck in correcting your problem.
Best regard
May 27, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Where to get power supply?
http://www.shopping.com/xPC-GeCube-Pandigital-8-Inch-Digital-Photo-Frame-with-2-Interchangeable-Frames
Mar 09, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
The EasyShare SV811 will not start up
please try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Jan 06, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Digital Frme wont turn on
I have an Optiumus digital photo fram and it won't turn on
Dec 25, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
7 inch digital picture frame
Where do I go to have my picture fram serviced???? It has worked fine. Then it shut off and will not turn on again. I pulled the power cord and left it off for a couple of days and then plugged it back in. That had worked before and now does not.
Jul 15, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Westinghouse DPF-1021 Digital Picture Frame, Digital Photo Viewer Logo
4,097 people viewed this question
Top Westinghouse Photography Experts
Ed Mac
teddyboy
Tom Chichester
Are you a Westinghouse Photography Expert? Answer questions, earn points and help others
