Question about Refrigerators
Avalon bay portable ice maker ice full light stays on when empty and doesn't make ice. Also, on-off light blinks continuously.
HVACRH20
  • 237 Answers
SOURCE: Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Posted on Dec 31, 2006
Fixe_You
  • 1800 Answers
SOURCE: Ice maker won't shut off when full
check the Shutoff Arm:
An arm extends away from the ice maker over the ice cube bin. During each ice making cycle, the arm rises up and then drops back down after the new ice is dumped into the ice cube bin. As ice accumulates in the bin it prevents the arm from dropping back down. When the arm is high enough, the ice maker shuts off and no more ice is made until the ice level in the bin drops.
The ice maker can also be turned off manually by lifting the arm all the way up into a locked position (shown belowef280e4.jpg
The arm is supported at one or both ends. One end extends into the back of the front support (see photo above). If it is not securely in place, it could cause the ice maker to malfunction. Confirm that the arm is securely in place.
For proper operation, confirm that arm is in the lowered position and that nothing is blocking it from normal movement.
To test the shutoff function, lift the arm up into the manual shutoff position. Recheck the unit later to confirm that no ice is being made.
If unit continues making ice even when the shutoff arm is in the up (off) position, refer to the diagnostic table or for a modular ice maker, replace the control module.
check the Shutoff Switch:
Before testing the shutoff switch, unplug the refrigerator to avoid an electrical shock hazard.
There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. Component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Modular units do not use a separate shutoff switch. Instead follow this link to view instructions for checking the shut off arm.
Posted on Jan 30, 2009
SOURCE: Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Posted on Mar 06, 2009
  • 63 Answers
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Posted on Mar 10, 2009
  • 523 Answers
SOURCE: ice maker wont make ice, light blinks twice in a
the eyes are bad
Posted on Jul 09, 2009
Hello, I have a portable ice maker model 102C igloo . the machine turns on but will not continue the cycle and the ice full red light comes on. Any answers to this problem are welcome.
The tray full may be triggered or stuck or another problem may exist. Look for what senses the ice being full and also check with Curtis support:
(another person was tld to do this and it workd:
1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hours.
I included some links for your convenience. Good Luck
1 How to fix portable ice machine part 1 of 3
Troubleshooting Portable Ice Makers
Igloo ICE102 WHITE User Manual Troubleshooting Guide
Apr 29, 2016 | Freezers
Ice full light continues to be on, will not make ice
Make sure the small emitter that sends a beam through the ice bucket to read ice height is not blocked or dirty...
Apr 21, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Ice full light on
There is a float switch or sensor in the basket. Have you got a manual?
Apr 13, 2014 | Sunpentown SPT IM-100 Portable Ice Maker,...
Ice full light stays on, so no ice
check for the sensor/ float switch that tells the machine it's full
Feb 22, 2014 | Oster Osim22sv 27-lb Portable Ice Maker
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
Add water light stays on when the reservoir is full
I have the SPT IM-100 Portable Ice Maker. After about 2 months, it stopped, telling me that it needed water, when of course it was full of water. I did alot of digging on the Internet to find a solution. There was none. It finally occurred to me that the water sensor might be calcified with our hard water here in Reno. BINGO!!!! I ran several cycles with lemon juice and vinegar (you pick your favorite non-toxic acid), and the damned thing started up again as if brand new.
Jul 24, 2011 | Sunpentown SPT IM-100 Portable Ice Maker,...
Ice maker not working
Press and hold the flapper in dont block the optics there is a light beam that goes across and you will see a u shaped notch in your ice bin on the door this determins when the bin is full when the beam is blocked it thinks the bin is full ..After pressing and holding the flapper in what does the red light do keep blinking ?? if so how many time before there is a pause and repetes if it stays on solid i need to know that too
Jan 28, 2008 | Kenmore 53703 / 53706 Stainless Steel Side...
Refrigerators Logo
262 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
