Question about Jensen Car Audio & Video
Have Jensen MP 5000. Doesn't turn on, the background blue light is there. No reset button noted. Removed from cabinet and found a loose pink wire listed as 12v DCTrigger wire. The fuses appear intact
  • 43 Answers
SOURCE: 1989 mustang horn problem
check the horn relay the horn button grounds the relay
Posted on Sep 29, 2008
SOURCE: Infocus LP 120
how can i replace the fan
Posted on Nov 13, 2008
  • 15935 Answers
SOURCE: dvd uv7i jensen parking brake pink wire how do i by pass this
put it directly to ground.
Posted on Dec 29, 2008
  • 783 Answers
SOURCE: 2001 Explorer Sport ,Rear Driver Brake Light and Turn Sig. Broke
Rear lights are double filament bulbs one side for the lights other side for the brake/turn signals so it still may be a bulb. Do u have a test light or volt meter you can check to make sure u have power there when brakes or turn signals are activated. Or just try another bulb.
Posted on Feb 12, 2009
  • 2605 Answers
SOURCE: f2 lights indicated. pup wont
Welcome to FixYa.
Based on your description " f2 lights indicated. pup wont stop when machine turned on. no water in cabinet. course fine filter removed. yellow plg removed to check for obstructions. none found." the good news...It is likely nothing very serious, but the "reset" requires some investigation on your part.
The "drain stuck cycle" or "F2" ( I presume you mean drain pump running constantly ) are directly related with overfill scenarios for Asko dishwashers of this era.
This is meaning the control is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen.
In the event it has, the outlet/drain pump motor is automatically turned on via either the pressure switch or a float in the base if sensing an overfill and removing water from inside the dishwasher will do nothing to resolve this error, but you can...
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base.
If the unit works fine after resetting the power/breaker it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump.
If not, there are a couple of other possibilities that I'd focus on.
**again insure power to the unit is off**
The first is the float and subsequently, float switch. If you've removed the service panel at the bottom, or toe plate, you need to locate the float and it's switch. It will be located directly behind where your main electrical junction is...
Once you've located the float behind the main connection plate, you should see something like this image below,
With the aid of a long screwdriver or if you can reach it, move the float up and down and listen closely for the switch to "click", indicating it is indeed functioning.
Restore power again, and see if this resolves the issue, if not try this next...
The pressure switch too can cause the drain/outlet pump to run constantly ( and usually all the lights to flash or "F2"...depending on the era and model of the Asko ).
As I was saying the pressure switch is the component which controls the normal fill level and the overfill detection...pre float activation. The float is primarily the last ditch safety to notify the user in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit.
It too is located under the machine and is mounted to the sump well assembly as shown, the large arrow indicates the switch while the small is the hose.
The issue is possibly just the hose going to the switch is clogged with debris such as dirt, detergent buildup etc and will be remedied by blowing it out.
The best way to do this is to remove this hose at the switch in the location indicated above, be very careful as to not break the hose off with the part of the switch inside, they can be delicate.
I typically work it loose with a tiny screw driver gently working it away from the switch. Once removed, pour a small amount of hot water, white vinegar or "CLR" through the sump from within the tub...or you can try blowing it through with "lung power".
The other end of the hose is located at the back of the sump well and is quite vulnerable to blockages over time due to detergents, dirt, and such.
This is the not break this or you will need to replace the entire sump fun.
Large arrow is pointing back to pressure switch, small indicates connection to sump well, sorry for the poor's hard to get in there with a camera phone, ha ha !
That's almost the extent of the possible causes of this error. Of course it could be the pressure switch has failed, the float switch has failed or ultimately the control has failed, but not likely.
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary.
Good luck.
Macmarkus :)
Posted on Nov 27, 2010
I just removed the back cabinet of a Whirlpool Duet Dryer and found a dead mouse where the power cord connects to the cabinet. Machine powers up but doesn't turn. I noticed that the neutral spli
if the wire has a metal end on it and its connected to the white wire, or neutral line, then something is wrong and that should connect to something
Jun 05, 2012 | Whirlpool Dryers
The pink wire doesnt go anywhere on my jensen mp 5000 in my cmping trailer
the pink wire is the switch wire for the parking brake which shuts the unit of whilst the parking brake is disengaged, if its disconnected then that should make the unit work all the time.
Check for loose wires on the red and yellow cables, also check the in-line fuse holder isn't loose.
May 10, 2012 | Car Audio & Video
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
I have no video was working fine and turned it on today and no video
most car dvd players have a brake bypass wire on the jensen i believe its the pink brake wire most likely the wire came loose or is not grounded rite
Jan 26, 2010 | Jensen VM9510 Car DVD Player
Jensen LCD JE1907DC keeps looping the Jensen intro logo.
I don't have a solution but do have the same problem.
I took it in a reputable shop and they told me the main board was gone and they could not get parts for it.
I just found out that Jensen is a Audiovox trademark.
May 18, 2009 | Jensen Televison & Video
The machine will not start. I removed the covered and air sprayed inside. With the computer plugged in, there is a small green light on but when pushing the on/off buttome, it does not start. Is there a...
Looks as if the connector wire to the power switch in front has become loose or removed from the pin provided on the motherboard due to the air. Check any loose connections or loose wires inside the cabinet & secure them. That should solve the problem
May 04, 2009 | E-Machines eMachines Desktop PC
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Jensen Universal Remote
Here for the Jensen remote just click below;
Here is link to the manual:
Sorry the manual was not the correct one for this remote. I thought it would provide simular codes to your product.
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Sep 14, 2008 | Jensen 143307 Remote Control
Product jensen uv8 nov. 2007 model in a trooper 1996 auto
The pink wire in most instances is the DVD's sensor that the vehicle is not in motion and is parked. It then allows the DVD player to display the movie not the warning message nor the blue screen.
Your description " wire on a bolt attached to the body..." indicates that said wire is constantly grounded. The DVD then cannot sense that the vehicle was parked. What this tell us is that the pink wire must first have a +12VDC before it is grounded. This changeover from + to 0 is the trigger. What is required is to have a single pole double throw switch. One end terminal is wired to ACC B+12 while the other to ground with the center terminal to the pink wire. Moving the switch from position OFF to ON (+12 to GND) simulates the parking brakes condition and will enable DVD playback.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 02, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UV8
go to setup hit 543210 but hold 0 then turn the bake override on and then hit the X
Dec 11, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
63 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
