Question about Swingline Office Equipment & Supplies
How do I replace spring in Optima 45 Swingline Stapler?
2 Suggested Answers
SOURCE: Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Posted on Oct 26, 2010
Spring has Sprung
Everything can be replaced, even a stapler.
Dec 10, 2015 | Swingline 87875 Optima ® 70 Desktop...
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
Staples will not come out of the stapler.
Did you use Optima brand staples? If not, the stapler will not work correctly. You must use their brand of staples or it will continue jamming, and giving you problems. The staples typically found right next to the Optima staplers in the office supply stores. They come in a rectangular metal box and are labeled Optima staples.
Sep 18, 2013 | Swingline Optima Electric Stapler 45 Sheet...
How to remove the cover of the Swingline 48209 Optima 45
The Optima stapler does top does not remove. To reach the inside of this stapler you have to "pull it in half". Do so at your own risk!
Aug 29, 2013 | Swingline 48209 Optima ® 45 Electric...
How to take apart a swingline Optima 45 stapler
i reloaded a optima 45 but when I tried to push the tray back in it seemed like the spring had broken and now it won't push the staples forward to use?? I don't see how to get it apart to realign the spring.
Mar 13, 2013 | Tools & Hardware - Others
How do I remove the lid of Optima 45 stapler
Pry on the bottom of each side and it will come up
Feb 15, 2013 | Swingline 48209 Optima ® 45 Electric...
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler '
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Mar 10, 2010 | Office Equipment & Supplies
152 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
