Question about Garden
Scagg tiger cat will not drive forward or backards
52 inch cut cranks and runs fine but when you engage the joy sticks you get nothing
3 Suggested Answers
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
Terry Corrow
  • 10875 Answers
SOURCE: 61 inch cut Scagg turf Tiger Blade removal. Is the top nut left hand or right hand thread?
righty tighty,,lefty loosy
Posted on May 06, 2015
How do you fix joy stick on z760
This is a known error. The joy stick has a (or more than one) bad connection on the printed circuit board. In the long run all connections will be lost. Sometimes if you press the stick n a certain direction it works, but the error will become worse, till nothing works. If you don't have enough skills to repair electronic equipment, please don't try to do this yourself. The soldering, demands special skills, so you don't burn the circuit board, because it is very thin. I think on Ifixit, you can fine at least a similar Kodak camera, to see how to open and close the camera. Also special tools and skills are needed.If possible, bring it to a repair store and ask in advance what they will charge you for the repair. In the mean time, just use it to take pictures and use the stick a little as possible.
Oct 12, 2014 | Kodak Cameras
Scag tiger cub
bad pto or bad safty switch not much goes wrong with scagg
Jul 14, 2014 | Garden
What would cause a loss of power at higher speed selections
Here are a few tips...Read your manual before operating any equipment. Chances are, you over heated the motor and it has a safety switch to shut it off before it ruins the motor. They call that a duty cycle.
TROUBLESHOOTING:
1. Motor fails to run or lacks power:
• Check battery connections for proper polarity.
• Check battery cables to ensure they are tight and have a proper connection.
• Make sure that the terminals are clean and corrosion free.
• Check the battery water level. Add water if needed.
2. Motor loses power after a short running time:
• Check battery/batteries charge, if low, restore to full charge.
• Do not run the motor for extended periods of time out of the water.
3. Do not use starting batteries with this motor.
NOTE: Do not use your crank battery as one of the supply batteries; crank batteries are not built for deep discharge service.
Jun 09, 2014 | Minn Kota Riptide SE 70 - Latch & Door -...
Scag tiger cat wont start
I would put new plugs in change the oil put a new in line gas filter in. After this tune-up check for spark by leaving the plug out on the moter body crank it over if the spark is hot you know its a gas problem also check for any grounding by starting it at night then looking around to the engine to see if its grounding out. Try these simple things. Do not change anything on the moter without doing these things first. Good luck
Apr 11, 2014 | Scag Tiger Cat 52 Zero Turn Mower...
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
New Holland DC 100 Dozer starts and runs but won't move. Bottom left warning light is on and can't find out what it is, there is no symbol on it. Guy who was running it said it was working fine for a few...
WE HAVE NEW HOLLARD DC75 IT WON'T MOVE FOWARD OR BACK BRAKE LIGHT STAYS ON AND SAFTY LEVELER WORK JOY STICK SAY IT IN FOWARD OR BACK BUT NOT MOVING WHAT TO DO?
Feb 17, 2011 | Garden
May 14, 2009 | Mtd Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
