What IA a mouse wheel - Computers & Internet
Mouse will not move items and keeps jumping around
As your PC is new, it's likely you have an optical mouse. Sometimes they are unable to sense movement on certain surfaces (glass, pure white paper etc). Try putting something under it - magazines or newsprint normally works well.
Apr 23, 2013 | Computers & Internet
Low vaccum on left side wants to grind in two wheel drive
on passenger side firewall behind battry ia a vacuum solenoid it's for the four wheel drive hub seals
ford had alot of problem with these there is a tsb out there for this replace this solenoid & it will fix you're problem
May 29, 2011 | 2006 Ford F-150
Unde pot gasi niste drivere pt acer aspire 5100...web..usb...mouse...keyboard..sunet..cardrider...
intra aici,selecteaza sistemul de operare si ia ce iti trebuie:
Feb 27, 2011 | Computers & Internet
Ksrg25 kitchenaid is running, cooling, freezing but making a clicking noise at compressor every couple of minutes or so?
there ia probably a mouse knawing a the rear entry conductor, it's warm and does have a slight vibration... be very quite and listen...
Mar 24, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Mbj58 wheel mouse curser wants to go all over screen
Hi a. Have you tried another mouse and
b. Are you using a glossy or prismatic mouse mat? Try using a different one or a sheet of A4 and see if this fixes it
hope this helps Mark
Aug 22, 2009 | Logitech Wheel Mouse Optical
Need repair on bunn commercial coffee maker
SWANSON SERVICE & REPAIR INC. 2115 GREENE ST. ADEL IA 50003 515-993-2272 DAN CONE GROUP - Refrigeration Certified 1056 27TH AVE SW CEDAR RAPIDS IA 52404 319-365-3325 GOODWIN TUCKER GROUP - Refrigeration Certified 935 33RD AVE. SW CEDAR RAPIDS IA 52404 319-365-1311 SWANSON SERVICE & REPAIR
CEDAR RAPIDS IA 52401 515-993-2272 COMMERCIAL FOOD EQUIPMENT - Refrigeration Certified 1113 W 4TH ST DAVENPORT IA 52802 563-323-1826 GOODWIN TUCKER GROUP - Refrigeration Certified 2900 DELAWARE AVE DES MOINES IA 50317 800-372-6066, 515-262-9308 GOODWIN TUCKER GROUP 3530 PIERCE SIOUX CITY IA 51104 712-277-0056 GOODWIN TUCKER GROUP - Refrigeration Certified 3175 W. AIRLINE HIGHWAY WATERLOO IA 50703 319-232-5049 SWANSON SERVICE & REPAIR
WAVERLY IA 50677 515-993-2272
Jun 19, 2009 | Bunn NHB Coffee Maker
Mouse wheel wont work
you replace the mouse.
check your mouse setting from control panel
your mouse wheel button is free.
give me detail
Apr 05, 2009 | E-Machines eMachines Desktop PC
My mouse is wheel is not functioning right
You need to determine if it a software or hardware issue. Check the mouse settings in control panel under the wheel tab (mine is set to 3 lines at a time). Do you have access to another wheel mouse to try? A new mouse is not expensive. If the scrolling works on another mouse the the wheel is defective.
Jul 20, 2008 | Dell U0636 Mouse
Mouse Wheel How can I get the mouse wheel to do "double click?" Help!!!
Download and install the latest driver/software for your mouse from the manufacturer's website. Once installed, you should be able to program the wheel through the software.
Jan 06, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
