Question about Denon Televison & Video
When my Denon AVR1603 is operating, it stops my RF remote control blinds from operating. Is there an RF signal coming from the amp when it is operating?
If the amp is on but there is no signal going to it, it does not stop the blinds from operating. I also have an RF operated doorbell which is also affected in the same way. Both these items are in the same room as my amp.
ripleymojica
  • 643 Answers
SOURCE: sometimes volume won't stop going up when I press +/- control
try programmin the ir code with a delay. .3 .4 usually will solve your issue. part of trouble shooting when the remote is connected to the server theres an option to increase or delay the ir emitter. hope this helps
Posted on Jun 04, 2009
  • 521 Answers
SOURCE: 2007 NITRO DODGE FRONT DRIVER & PASSENGER
could be but unless you actually check with Chrysler motor corp or you local dealership you wont know for sure. a Service bulletin is usually issued to dealership by the manufacturer if they identify a common problem. Just check with you r local dealer and all will be good in the end.
Posted on Aug 03, 2009
  • 234 Answers
SOURCE: Blower motor doesn't come on. Traced electrical
That is a BSC, or blower speed controller. This is a very common concern, in most cases if you simply wiggle the harness the controller will start to work.
This should be located on the a/c case under the hood below the heater hoses.
Posted on Oct 20, 2009
issikiki
  • 563 Answers
SOURCE: My remote control stopped operating my Boston
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Posted on Jan 26, 2010
  • 3 Answers
SOURCE: Reiker ''room conditioner'' heater stopped working
I've also had this problem. Solved it with the reset button on the back of the remote. It's under the battery cover, next to the dip switches.
Turn on the remote, with heat. Then, at the wall switch or circuit box turn off power. Wait a few minutes. Restore power and within 30 seconds with remote in range of fan hit the reset button. You should see a countdown from 5-0 on the remote screen.
I did this and the heat started working again.
Posted on Feb 17, 2011
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
ROCKFORD FOSGATE X7a Amp, I need compatiable remote control knob.
It will NOT work!
You need p/n AP-3212. If you are in USA then contact Rockford for this part number.
Aug 11, 2009 | Rockford Fosgate Type RF X7 Car Audio...
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
What is a ?????
The RF extender is a add-on device that communicates with the Harmony 1000 remote. You would actually hook up IR eyeballs to your equipment and then plug them into the RF extender. This allows you to have your equipment in a cabinet or closet and have the door shut. The Harmony 1000 sends RF signals to the RF extender and the RF extender sends that signal to the components. This way you don't have to point at the components to control their operation.
Hope this helps, if it did please indicate with vote.
81
Feb 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
URC-9910 remote: The RF part for this remote stopped working.
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
Televison & Video Logo
43 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
