Question about Sony Televison & Video
Sony 46" KDL-46Z4100 A-1564-648-A V.1 T-Con Timing Control Board is it bad?
2 Suggested Answers
  • 75017 Answers
SOURCE: Sony 46 KDL-46Z4100 A-1564-648-A V.1 T-Con Timing Control Board is it bad? I have 1 min video of screen but I don't know how to upload it.
Contact the authorized service center for Sony. This T'Con board is not available at local electronic spare part market.
Posted on May 19, 2017
I have a 46" Sony Bravia TV that has colored verticle lines about 2-3" wide just left of center.
Yor tv have problem with T con board. T con board is one which drives the pixels of the LCD panel. If any of the driver satge in the T con board is faulty then this problem can occur.
Some times bad contacts on the connections of the t con board can cause same problem. Remove the tv and find out the t con bard. Remove the connections to it and the reconnect the connections. Then check, if the problem remains the same then the tv need a new T con board.
You have didn't mentaioned any model number of your tv. So it is not possible to show you exactly how T con board looks.
Normally in all lcd tvs the tcon board is place on the bottom or top middile position. Which will be cover with metal cover or aluminium foil.
Here I have added a link which will lead you to the picture of T con board for toshiba.( Not exact one)
T con
Apr 29, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
We are having issues with the screen. The display of our Sony Bravia KDL-40V4150 shows straight vertical lines all the way across the screen. How do we fix this issue?
Sounds like a defective T-Con board, but it is better to test it before replacement. Also there is a possibility to repair it at a lower price. You can find a company that is testing this kind of T-Con boards and repair them here:
Sep 17, 2013 | Sony Bravia KDL-40V4150 40 in. LCD HDTV
Permanent vertical line on my sony bravia 46 inch LED TV
tried to re seat the cable at the t-con board which may have loose contact. if can not get with re seating, the t-con board has problem.
Aug 02, 2012 | Sony BRAVIA KDL-46V3000 Television
The T'Con board [Timing Control Board] of your TV has the fault. Check its strip connections for rigidty. If the connections will get loose, when heat up, the fault you describes her can occur. Check it first. If all are OK, repalce it.
2_7_2012_2_14_58_pm.jpgThis is the picture of the t'Con baor to your TV. Check the backlight inverter board too for any loose solderings. 2_7_2012_2_15_39_pm.jpg2_7_2012_2_18_56_pm.jpg
Feb 07, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
On my Sony KDL 46 W4100 W the right side of the screen gets dark with colors dark and reddish. After a couple of minutes picture looks fine. Any idea what it could be? And approximately how much will it...
Typical repair shop for 46" flat panel TV repair will be about $200 and up plus parts.
The problem you have can be caused by T-CON board or bad LCD panel, I would swap in the T-CON board first.
See example here: L140 uses almost the same board as 4100 series.
Learn about T-CON/LCD panel failure here:
T-CON/LCD PANEL troubleshooting:
If the panel is bad, then forget about repalcing it since the panel will cost more than new 46" TV.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Oct 07, 2011 | Televison & Video
WHERE CAN I BUY A SONY T-CON BOARD PART NUMBER SONY 1-857-132-11 ? IT IS FOR A KDL-52W4100. 2" Vertical stripe problem all the way across the screen. fades in and out. If iI try resoldering the...
The part # you gave is the Control Board which sells for $668.79. The T-Con board your looking for is part of the LCD Display Panel and is not sold separately. I suggest you start by cleaning the ribbon cables from the control board to the t-con board. If that doesn't help then you had better take it in to a service center to verify which part is bad because there are no refunds, only replacement after you buy a board.
Nov 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony KDL-46S4100, picture is green. Started as intermittent problem but is now constant
Replace the T-Con Board. Yes type the model and T-Con they cost like $45 to $75 you can go to is a good service part store.
Nov 04, 2010 | Sony KDL-46S4100 46 in. LCD TV
Open Questions:
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
