Why is my 58STA/STX dripping water from a pipe that then dripps into the drain pan that dripps outside. The amount of water dripping outside is increasing,
SOURCE: water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Posted on Sep 23, 2007
  • 72 Answers
SOURCE: Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Posted on Jan 27, 2008
  • 700 Answers
SOURCE: Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Posted on Jan 21, 2009
  • 867 Answers
SOURCE: A small amount of water is leaking out of the
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Posted on Sep 14, 2009
Testimonial: "Thanks, I will check it out and see if I can find the pan. Have had trouble with the ice maker leaking before but this seemed different."
SOURCE: water leaking into the drain pan
Water is leaking from under our Samsung refrigerator model rf267aebp. Could the drain pan be full and where is it located?
Posted on Jan 30, 2012
LG ptac MODEL : LP153HD3A collecting condensation water in bottom but not going to outside drain pan.
there is probably a blocked pipe or filter it will need cleaning, you may need a pump to remove the water first to get to the pipe to clean it out.
Jun 19, 2017 | LG Heating & Cooling
Condensation water does not leave pan when it gets full you can hear the water being picked up and thrown around in the unit. There is no water flowing either inside or outside unit.
What you hear is an indication that the drain hole in the drip pan is clogged. Check the outside of the bottom of the drip pan. The hole may be hard to locate, as the clog can blend in with the drain hole. It may take patience & persistence to find it. A pipe cleaner works well to clear the hole. And while you're at it, check the downward tilt of the rear of the unit. The general rule of thumb is 1/4" to 1/2" downward tilt. This will help to water to flow to the rear of the drip pan and out thru the drain hole.
Hope this helps you and thanks for choosing FixYa.
Sep 05, 2011 | Electrolux Heating & Cooling
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
We live in an apartment complex and have a Trane Air Conditioner, each unit has its own central air. I believe the one in our unit has clogged drain pipes, when we first moved in we didnt change the air...
Hello You have to cut the pipe and blow out each end,You can use a 1"rubber hose from an auto parts store & 2 hose clamps, If you can't find the end.This will allow access in the future to clean out the pipes.It will slip over 3/4" PVC pipe.They sell a PVC pipe cutter but a hacksaw blade works well.Get ready for all the water in the pan once you cut!
Sep 14, 2010 | Heating & Cooling
Water on flour of water heater
If your water tank is leaking, is it dripping from above or actually leaking thru the bottom?. Can you find the source? Feel around and try to find wet spots above and around it. If it's not leaking from the water pipes or T&P valve, it's your tank leaking. You'd be wise to have it checked out in the morning, before it gets worse. Hopefully your catch pan has a pipe attached to divert water to the outside or to a sump pump or floor drain. Water heaters do sweat, but you can tell the difference if it continues to leak for several hours.
May 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Dripping water from the pvc drain pipes of 2nd story eaves.
yes, that is your emergency drain pipe. You need to have the a/c drained cleaned out. It is probably jammed up with algea. A professional should be called to blow it out. or get ahold of your Mr. Fixit buddy. If you leave it like this your drain pan will eventually rust out and cause major interior damage to your home.
May 14, 2009 | Heating & Cooling
My Daewoo DSB 091L unit has started to drip condensate from the casing joint underneath the front drainage tray. I have cleaned the blocked drain pipe and proved the water drains away. The condensate drip...
Make sure that the flexible pipe is securely connected to the drainpan, it can come adrift and cause leaking. The way to check this is to make sure everything is dried out completely. Then open the front grill and carefully pour water so that it goes only into the drip pan. Pour slowly so that you do not overflow the pan. If water is coming out on the outside and you have no leaks on the inside, then you can rule out the perished or disconnected drainpipe theory. In this case your unit may be short of refrigerant causing excessive run time and a freeze up of the evaporator.
Mar 24, 2009 | Heating & Cooling
Jan 25, 2008 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
