Question about Vacuums
My tax Pet Steam Cleaner is not producing steam...the trigger mechanism appears to be pumping fluid but there is no steam.What is the likely problem/solution
SOURCE: steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Posted on Sep 10, 2008
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
  • 26 Answers
SOURCE: i have the steamtek steam cleaner for 5 months and...
We had the same problem. I took the unit completely apart and it seems it doesn't like our hard water. I took off the head (one screw at the base and it slips off) and I put a tooth pick into the steamer hole to clean any clogs. Then I ran a cup of CLR through it with equal parts water and it runs fine but not as good as it did new. We are going to only run distilled water through it from now on. Hope this helps!
Posted on Jul 26, 2010
heatman101
  • 43501 Answers
SOURCE: My shark steam mop is not producing steam when I
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 22, 2010
Repair Polti VT Evolution steam cleaner doesn't work
Steam nozzle/lines are probably clogged. The minerals in the water will eventually clog up the system, you need to use only Distilled water whenever possible to eliminate as many minerals from the water as you can. If the screws are spinning and not coming out, you will have to pry up slightly on the cover the put pressure on the inner parts so they will come apart. Easiest way is to push something like an old credit card betwen the seams and pry up carefully. go slow and easy so you won't break anything.
Aug 20, 2014 | Vacuums
Bissell steam mop
-Pump is out (Broken). or water line is clogged.
Good Luck
Mai
Aug 19, 2014 | Bissell Lift-Off Steam Mop, Titanium, 39W7
Shark portable steam cleaner heats up but does not produce steam
Built in thermostat...sounds like you need to buy a new steamer.
Dec 12, 2013 | Vacuums
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
It is getting up to tempeture but it will not produce any steam
Your machine need to reach boiling point to produce stem? Then check if all the sustem is sealed other than the pip outlet gun and it should now operate with the gun trigger ( pull to operate, but only when the water within the vessel is boiling, producing steam)Hope this helps Regards Mike
Jul 08, 2011 | Polti Vaporetto 2400 Canister Steam Vacuum
My Shark steam cleaner isn't producing any steam. It has water, has warmer up a sufficiently long time and I've pumped it repeatedly. Any ideas?
Yeah. its broken...
heatman101
Sep 12, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mini steam zapper heats but produces no heat
you should get steam in the amount of time it take to boil water
Feb 18, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Steam won't shut off
I have portable steam sharrk, had same problem. I filled it with water and now works fine, water level might be to low
Jan 07, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Bessell steam cleaner #%$@#%%$%
Model number would help. With water squirt out of the hose? If it does then the heater in the handle is probably clogger and will have to be cleaned out. If no water, then is the pump belt ok? If it is then you could have a bad pump. Also check that the seal is on the bttom of bothe tanks, and not sitting in the hole that the tank sits in. It has to be on the valve on the bottom of the tank.
Feb 13, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
