Question about The Watches
I have an LED godier abyss touchscreen watch, the glass broke on it, and was wondering if there was any place I can get the glass or get it repaired?
3 Suggested Answers
  • 203 Answers
SOURCE: broken glass of my cartier watch
search for horoligsts on the web some of them can cut new glasses. if this helps please rate joe
Posted on Dec 16, 2008
sunnysolanki
  • 261 Answers
SOURCE: I broke the glass on
It is not so much big problem.You can repair it on a local watch shop around your home.
Posted on Jan 21, 2011
I DROP MY WATCH CODE REF IS 1142 I BROKE THE GLASS WHERE CAN I BUY A REPLACEMENT GLASS FROM
Getting a glass shouldn't be a problem, but as it sounds as though you intend to fix it yourself, then please be aware of the following.
It is essential to get the correct size glass - even 0.5mm difference in the diameter means either it won't fit or it's too small and falls out again. As you say that the glass is broken, I would be surprised if you could remove it and still determine the correct diameter.
You need to think not only about how to remove the broken glass, but also about how you are going to fix the replacement one. Many watches have a very fine plastic ring around the glass that holds it in place and this may have also been damaged.
Also, with many watches it's necessary to remove the back, crown and movement to effectively replace the glass.
If your watch has any sort of water-resistance rating then it would need to be retested afterwards.
Bearing all this in mind, I strongly advise you to take your watch to a reputable watch repairer and let them sort it out.
If the glass is anything other than round, then the cost tends to go up. Get an estimate from them first, and decide if what they will charge you is reasonable - if it isn't then spend the money on a new watch.
Hope this is helpful.
Oct 22, 2017 | The Watches
Broken rod
what you need is a new spring bar. Its a very simple fix that can be done by a watch repair place. should cost no more than 10 dollars.
Basically a spring bar holds the band links to the watch. Its a common issue sometimes caused by wearing your watch to tightly.
Simple fix , anyone can do with proper tools and spring bar.
Jan 27, 2012 | Watches
How much
The Abyss 10.900 is a waterproof diving watch that features a silicone filled stainless steel case and stainless steel unidirectional bezel on a black rubber strap. Silicone is denser than salt water, making the Abyss water resistant to grater depths. 10.900 is the depth in meters of the deepest location on earth, the Marina trench in the Pacific Ocean. The refractive index of silicone enables you to see the dial and hands from any angle under water. You can typically buy this watch for about $425.00
Jul 17, 2011 | TechnoMarine Abyss ABS01 Watch
I have a Technomarine abyss, bought as used and don't know if working. Once open to change battery I found that there's oil also in the bak where is tored battery. Is it normal or the watch is...
Hi. It has silicone oil in it. To tolerate diving to that depth the watch is capable. It is normal, but if the silicone has to be completed if some leaked. Take it to the repair service. Best regards!!!!!!
May 13, 2011 | TechnoMarine Abyss ABS01 Watch
I broke the glass on this watch. Where and How can I get it repaired? Thanks!!!
Jan 21, 2011 | Tommy Hilfiger Antiqued White Flagstaff...
Broken galss
mcdevito75 here, helloarcus, look for a small watch repair shop in your area in Hong Kong you shouldn't have any problems getting a new glass (crystal) for your calvin Klein watch, However since you say the watch is new, contact Calvin Klien and let them know of the broken glass, see if it's on any kind of warranty, the paper work with your watch should have the contact info.
Jul 11, 2010 | Calvin Klein CK Biz K7741126 WW Watch for...
I Have a problem with my Technomarine ABS05. There is changed a battery by someone. but the watch doesnt work. I removed the back and some oil came out. where can i find that sort of oil? How can I change...
Oil should not come out of a watch. There just isn't that much oil in a watch to have it dripping out.
Are you sure it wasn't water? I can see where moisture could have gotten inside the watch if it was not sealed properly after the battery change.
The fast mall battery change places, jewelers and mart stores do not hire people that are trained to change batteries properly. We have a love hate relationship with those places. We love them because they keep us in business with all the watches they damage. We hate that they are in the business of replacing batteries in the first place because of how many watches they damage.
If you had one of those cheap battery stores replace the battery most likely they did not reseal your watch and it got water inside. This water will cause the problems you have now with your watch.
You will need to have a qualified watchmaker repair your watch.
Hope this helps,
Ken
www.yellowstonewatch.com
Apr 16, 2010 | TechnoMarine Abyss ABS05 Watch for Men
Skagen watches - the glass broke
Any watch repair shop can replace the glass. Find the nearest one and ask for help.
Jul 29, 2009 | Skagen 170LTTM Wrist Watch
Marcel pocket watch - face broken
where I can find the glass becouse I broke mine please help me to find a place where I can buy it
Jul 06, 2008 | Watches
Broken glass of my cartier watch
Jun 04, 2008 | Cartier 21 Chronoscaph W10125U2 Wrist...
Watches Logo
29 people viewed this question
Top The Watches Experts
D. E. Hev
John mullen
vince
Are you a The Watch Expert? Answer questions, earn points and help others
