Question about Home Security
Light does everything EXCEPT come on when motion is active.
Brinks motion activated security light model 7160w. Only stays on for about 15 seconds. Setting is on 10 minutes. Can someone help?
Sounds like the motion sensor is not picking up motion. Or, does it actually sense motion and only stay on for a short time each time? Try moving the setting, if this is the case and see if you see ANY change. If not, then replace the motion sensor.
Oct 24, 2014 | Home Security
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 differemt locations?
One of the switches needs to be a 4-way then the PIR will act as any other switch. The downfall is if the lights are on and motion is sensed they will turn off.
My preference is to connect the contacts of the security device across the travelers of the three way circuit. The travelers are probably the red and black in the three conductor cable. When motion is detected the lights will turn on regardless of the settings of the three way switches then after timeout they will turn off. If they are turned on with one of the three way switches nothing will happen when the motion detector turns on except you cannot turn the lights off until the security device has turned off.
I hope this helps. The motion contacts need to be isolated from the motion detector power.
Feb 20, 2014 | Electrical Supplies
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 different locations?
Here is a page of diagrams: http://www.do-it-yourself-help.com/3_way_switch_wiring.html
You have to use a 3 way switch on both sides. You should be able to get a motion light that has an always on feature. To activate the feature then you need to turn the light on off on fast and then it stays on. Ceck with home depot or someplace like that for lights with that feature. IF not then you are going to need to run another circuit.
Ds 924 motion detector
It may have been previously learned into a zone. Sometimes, the motion will trip and activate a signal that can be learned into another zone you are trying to program. exit programming, then "tamper" the cover for the circuit board, not the battery access, on the motion, check the "status" light to see if a zone is displaying "tamper". Also check battery orientation in back of motion. When battery is first installed correctly. The light should activate during the first minute.
Sep 15, 2017 | GE 60-511-01-95R - ITI Wireless DS 924...
Lost instructions and do not know how to reset so it activates by motion.
goto
http://www.heath-zenith.com/servsup_install.cgi
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 23, 2011 | Heath Zenith Secure Home Motion Activated...
Motion senser games
with the videos , i cannot help you... everything i can say is to try finding videos for the kp500 resolution...(try rotating it to the left... for landscape view)
2. motion games. there aren't motion sensor games for kp500, except the ones you got with your mobile... but there are touchscreen games that you can play on kp500 : www.mobile360.org
Feb 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Motions don't stay active when doors and windows are on too.
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
Jul 12, 2009 | GE Security Simon 3 Wireless Home Security...
Dome light isnt working
The courtesy lights are controlled by the BCM/body control module, it can be tested for faults as well as active tests of the systems it controls, which is just about everything except the eng and trans.
Nov 12, 2008 | 1998 Chevrolet Cavalier
Home Security Logo
20 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
