Question about John Deere Garden
I have a john deere srx75 rear engine mower the tractor works great only in reverse.when i push the lever to go forward an give it gas its just makes a loud grinding noise an wont move any ideas
  • Jonathan akerly May 19, 2017
    I dont think it is it has forward neutral an reverse,an a gas pedal.doesnt look like the trans uses oil looks like its just grease
  • John Deere Master
  • 7,515 Answers
If you want to solve your problem, click on the link I attach.
Best Manuals
Posted on Jun 08, 2017
tripletauto
  • 1450 Answers
SOURCE: John Deere LT190 Lawn Tractor transmission problem
is it hydrostatic drive? if so you probably need to change filter and fluid
Posted on Oct 01, 2008
SOURCE: John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Posted on Mar 23, 2009
mickey813
  • 472 Answers
SOURCE: my craftsman lawn tractor has a 42 in. deck, w/21
YOUR TRANS IS BAD
Posted on Oct 02, 2009
  • 640 Answers
SOURCE: I replaced both belts on
Likely the belt is mispositioned or somehow in a bind.
Posted on Aug 22, 2011
machinist84
  • 25 Answers
SOURCE: I have a John Deere
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Posted on Aug 26, 2011
John Deere SRX75 Riding Mower unable to push when placed in neutral.
check that there is not a system that when in neutral , the park brake is not engaged
Oct 14, 2016 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
JD SRX75 - when push lever forward or back, tractor does not move..
check the lever on the rear of the tractor used to puch the unit when not running then check the belt
Mar 31, 2012 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere LT155. When you let off of either the forward or reverse pedal the tractor comes to an abrupt stop. It will actually lock the wheels.
Hi, most likely the brakes are hanging up. Follow the brake pedal path to the rear of the mower, it is attached to a small arm on the side of the diff that is probably locked forward. This lever and the pins behind it need to be freed up so the lever operates forward and backward freely when the brakes are applied and released. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere 22HP VTwin Hydrostatic 42"...
John deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
May 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere L120 riding mower with IntekV twin 22hp
Try replacing the gas in the fuel system. The manufacturers are telling us that gas over 30 days is considered bad gas.
Good day.
Nov 02, 2009 | John Deere Garden
Mar 23, 2009 | Garden
Garden Logo
48 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
