AIRCON SIGN ED AND CONDENSING UNIT P6 - Heating & Cooling
Carrier aircon 5A Sign
What is your question? If not working: check fuse box in house and by A/C unit. Some units have their fuse box by the unit. If it is not cooling, may need coolant. Call the 800 number for Carrier and they can help.
May 16, 2016 | Carrier Heating & Cooling
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
Nov 18, 2013 | Konica Minolta Bizhub C550 Color...
What is the causes of p21 and p6 in konica minolta bizhub c550
replace the black image unit and clean sensors under the transfer belt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
Can't lower cooling temp
Is you indoor fan running? Is the out door unit running? (Condensing Unit) If both are true, is the larger of the two copper lines on the Condensing Unit colder than the smaller one? If not, is the compressor in the Condensing Unit running? The compressor is the big can under the fan in the Condensing Unit. Please reply to this as you may need a service tech. at this point.
Apr 01, 2011 | Heating & Cooling
Aircon wont start up, the LED just flash and the remote wont stop or start the unit
That's a sign that there is a problem with the circuit board. Have a professional check it out.
Apr 04, 2010 | Heating & Cooling
Ice forming on front coil of aircon blower
the front coil or evaporator is not absorbing heat from the conditioned space or the condensing coil or back one is not rejecting heat. usually this is due to dirty coils or clogged filters
Nov 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi my aircon pump has on power to it
look for blown fuses to condensing unit or broken, loose 24 volt wires also to condenser.
Sep 01, 2009 | AmcorAire UCHW-H18AF2 Split System Air...
Outdoor fan is running continuously without using Wireless Remote Controller
Bad control board on the condensing unit up top. The board needs to be replaced as it is sending the message that the system is calling for cooling/heating all the time and doesnt know what to do. If you continue to let it run this way you will ed up having more major issues
Jun 01, 2009 | Fujitsu Heating & Cooling
Hyunai A/C Unnit
Yeah, only a qualified or pro aircon tech can replace it. Also the evaporator coil needs to be check for leak. If your unit is still under warranty better call the manufacturer. Anyway, here's how aircon works:
Window air conditioners work on exactly the same principles as a refrigerator or dehumidifier. They have a cooling system that refrigerates the air entering the unit. The moisture in the air condenses on the cold coils and drips into the bottom tray of the air conditioner. The warm air in the room is drawn over the evaporator coil, which collect heat. The heat is conducted into a refrigerant gas. The gas is then circulated to the condensing coils on the back of the unit where it is dissipated to the outside.
Sep 05, 2008 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
