Question about HP Garden
I have a large 27 hp Club cadet has been great. I was mowing along just fine and it just stopped moving forward. the engine was running fine and the blades were tuning just no forward or reverse?????
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
wadembly
  • 513 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 1111 Answers
SOURCE: Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Posted on Jul 17, 2009
  • 2841 Answers
SOURCE: tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Posted on Sep 01, 2009
SOURCE: Sears ZT 7000 mower, engine runs, mower will not move
Same problem. The drive belt pulley tensioner spring broke. Replaced and everything worked great.
Posted on Apr 05, 2010
I have a cub cadet Gt1554 with the 27 hp kohler command. Everything runs great but it doesn't have near the speed I thought is should have. Is there a simple fix to this
It is only going to go about 5 miles per hour. If you wanted something faster you should have gotten a zero turn mower. You can get it to go a little faster by untightening the clamp on the engine that holds the throttle cable and moving the cable forward a little. Most mower engines are set up to only run at about 2/3 throttle from the factory.
Aug 23, 2015 | Cub Cadet Garden
1050 Cub Cadet
Fit new spark plugs and new fuel filter.
Jan 09, 2018 | Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
32 people viewed this question
Top HP Garden Experts
solver2010
andrewdwhite
ray gallant
Are you a HP Garden Expert? Answer questions, earn points and help others
